I get a an error after installing my nivida graphics card to use dual monitors error: invalid display settings currently selected graphics display driver can not be used. It was written for a previous version of windows ( what is that about? this pc is only 3yrs old)
  • Imre Vetro May 11, 2010
    Tell us the exact card type and the OS plz.
    New Friend:
  • 41 Answers
In that case, your pc might have a conflict.. it maybe the version of the display driver.. perform a clean install on the video card driver by doing this.. assuming that your PC's OS is WinXP..
1. On your desktop right click the icon My Computer and click properties..
2. On the System properties click Hardware then click Device Manager..
3. On the device manager window look for the display adapters then click the + sign on the left side..
then it will shows the display adapter you have on your pc..
4. Right click your display adapter then click uninstall.. from there your pc will remove the display adapter you select then it will ask you to reboot..
5. Now were assuming at this time that your pc has been rebooted.. Browse your Display driver and then install..
hope this will help..
Posted on Dec 05, 2008
Nvidia geforce3 (nv20) double monitor set up
Step 1 Make sure the second monitor is connected.
Step 2 Right-click on the Windows' desktop, then select Properties. This will open the Display Properties dialog.
Step 3 Select the Settings tab. This is where you set your monitor resolution, we'll come back to that...
Step 4 Click on the Advanced button. A number of tabs be displayed, select the NVIDIA tab that says "Geforce xxxx " or "Quadro xxxx ". The "xxxx" will be the model of your graphics card. Click the button here labeled Start the NVIDIA Control Panel.
Step 5 In the Task list on the left, under Display, select Set up multiple displays. Then set the nView Display Mode parameter to Horizontal Span. Click the Apply button.
Before proceeding, confirm that the second monitor is now working.
Step 6 Set Touch's settings for the second monitor as described int he section below.
Feb 18, 2012 | Computers & Internet
I installed my graphics card and no display comes up for either monitor. i am trying to setup dual monitors on my computer. When I try to install while my computer is on with one monitor it freezes my...
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps
May 15, 2011 | EliteGroup ECS N6200A-512DZ-H GeForce...
I have installed XFX GeForce 6200TC 128 Mb card and drivers from the supplied driver disc that came with it. i cannot get it to display dual monitors when i go to windows display settings! can u assist...
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes hope this helps
Apr 21, 2011 | XFX GeForce 6200TC Graphic Card
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
Need to connect 3 monitors. Want to use either a Nvidia 290 or ATI Radeon 9250 plus the VGA port. Installing the dual-video card disables the VGA port, cannot get it back. Help!!!
Use your AGP dual-video card for two and using a PCI VGA card for the third. It is best if the same manufacturer video driver is used for both cards, as two different ones could be problematic.
Jun 25, 2010 | HP Compaq Business dc7600 PC Desktop
Trying to get 2 monitors working
plug your LG display into the DVI port and the BENQ into the VGA? it may just be a random compatability error.
May 04, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
IX Micro IX3D twin turbo Graphics Card for PCI on my mac under osx tiger, my second screen stays grey
If you are running windows, (which I presume) try rightclicking on dektop, select properties, then settings (or the vista equivalent of that), select the second display, and check the "extend desktop to this display" box.
I hope this helps,
Yannick
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
DUAL MONITOR RESOLUTION
At a guess it is the refresh rate the video card is sending to the video out. What is the Max Resolution of the monitors and refresh rate ??
I would think there is a program to be able to setup the driver refresh rate and resolution don't use window drivers get the ones from the makers of the card rather than using the default nivida drivers
Mar 24, 2017 | ViewSonic OptiQuest Monitor
Invalid format when conected to laptop
Go into your control panel. Select display. There will be a picture showing 2 screens. Select the 2nd screen, and lower resolution to it's minimum. Apply and test. Slowly increase till you find what your happiest with. Worked for me using a ASUS laptop and LG60'plasma.
Jun 29, 2008 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
