The arm on my sanyo turntable does not pick up and return to its stating post at the end of the record
  • mkozodoy Feb 08, 2009
    JVC L-A31 turntable- when STOP button is pushed the arm lifts, swings back toward the rest but then returns and drops onto the record about 1/3 of the way in from the edge.
  • Anonymous May 22, 2009
    The tone arm on my turntable keeps returning to the LP once the record has finished playing. Then it goes back to the starting position and then it returns to the record...it repeatedly does this. Anybody know a fix?
  • 51 Answers
There is a cam on the underside inside the case with a screwdriver adjustment that allows you to adjust this.
Posted on Dec 05, 2008
Turntable arm will not lower - the guide just pushes it back to the off position
Try to do this
1. unplug the turntable
2. raise the arm
3. put it over the record
4. lower it which will not lower you said
5. push the arm to the very end close to the label
6. rotate the turntable by hand and it should take it through the whole return cycle of the arm and lower and finish the motion
7. then plug in and it should come back to normal
Dec 26, 2016 | Audio Players & Recorders
Picks record ,clicks twice ,returns record without playing
Mechanism for moving arm over and onto record is fubar. Probably stuck and the clicks you hear are the motor fighting a losing battle and returning arm to rest mount.
Remove stylus and play with arm and simulate turn on cycle to see how it works and where the jam is- fix and then put stylus back in - those little suckers are expensive.
Dec 06, 2015 | Audio Players & Recorders
How do I adjust the arm when it won't go to the end of the record?
Usually, the arm won't reach the end of the record when the arm pivot or auto-return mechanism requires lubrication.
May 17, 2015 | Audio Players & Recorders
Why does my Memorex 2650MMO turntable shut off after 20 seconds of recording?
The tracking is way off. Start it with the arm cued and see if it does the same thing. If there is no concentric motion moving the needle towards the center post, then the issue is the tracking. There is a sensor that tells when the arm has reached the end of the record.
Sep 17, 2014 | Audio Players & Recorders
My turntable turns and the arm moves onto the record but then the arm moves back and the turntable shuts off. What's wrong?
The auto reject/auto return lever has been advanced therebt tripping the arm to return to the pick up rest.It needs adjustment.
Jul 13, 2014 | Denon Audio Players & Recorders
The turntable turns and the arm lands on the record but then it moves back to rest on it's base and shuts off. What's wrong?
The auto reject/auto return switch setting has been shifted.It needs to be readjusted possibly at a specialist repair shop.It's the small lever that trips when the pick up reaches the correct end of the record run out grooves.
Jul 13, 2014 | Denon DP-29F Analog Turntable
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Tone arm ejects before reaching the end of a record
You need to get a service manual for the turntable and see how to adjust the tonearm. Sometimes there is a screw that needs to be adjusted by the tonearm. It may have a rubber cap covering it.
Nov 16, 2013 | Audio Players & Recorders
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
Record will not play to end.
There is a mechanism underneath the deck which senses "end of record". This is operating too early and will require adjustment.
Dec 30, 2008 | ION Audio TTUSB10 Turntable
521 people viewed this question
 Grubhead
Grubhead
