Question about Toshiba 42H81 42" Rear Projection Television
Picture compression My television started to compress, have flickerib lines, would freeze but today there is no sound or picture. This began to occur after a move to another residense. Can you help me. Thank you
We bought a new flat screen tv. Thanks anyway.
Posted on Dec 11, 2008
Picture comes on ok to my LN40C550 Samsung, then colored lines begin to appear through the middle of the screen, almost like a colored bar code
Sounds like a T'Con board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Samsung LN-S2651D 26 in. LCD Television
My sony sxrd 60 inch has the picture turning off and on (I notice the lamp turns off when this occurs). The green light is solid with no lights indicating the lamp needs to be replaced. The only time it...
Replace your Lamp and you should be just Fine. Call Mats 1-800-628-1118 or Look on line Encompass Parts Distr. they will list your Lamp # or Call them 1-800-638-3328 also Look under E-Bay I found my Lamp for 85.00
Nov 18, 2009 | Sony KDS-60A2000 60" HDTV
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Flashing green light and black screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Mar 12, 2017 | GE 13GP243 TV
Picture is compressed
Defective dap in vertical deflection ckt, or bad driver in same....accordianman
Jan 12, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Sanyo DS31520 31 Picture problem
hi there, it is worth for fixing it, cheaper than replacing it. you have a vertical section problem. look for a quilified service personnel for it to fix. ty
Nov 12, 2007 | Sanyo DS31520 31" TV
Partial screen picture
bad caps in the vertical section
Dec 14, 2006 | Quasar SP-2722 27" TV
Compressed picture, staticky quieter sound
Sounds like you've got a vertical deflection problem causing the shrunk picture and finally a solid bright line. As to the loss in brightness you may be losing screen voltage to your picture tube. Probably it is time to shop for a new tv since cost of repairs may be too much. Stargazer
Nov 15, 2006 | Philips Magnavox 20MT133S 20" TV
Toshiba 42H81 42" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
