Question about Refrigerators
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
Whirlpool side by side refrigerator light will not work. the lights in the freezer side work. ensured new light bulb works, took out door switch and it seems good, have power to switch what is left? I have a stainless still side by side Gold series and the refrigerator side light does no work along with the control panel. I have replaced the door switch and nothing still works. The cooling works fine. I am lost.
GS6SHEXNS00 model number
5 Suggested Answers
  • 33 Answers
SOURCE: HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
if its a 2 wire switch if you jump the 2 terminals together on the switcht plug the light should come on if it does replace the switch
Posted on Jan 01, 2008
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Posted on Jun 30, 2008
  • 1891 Answers
SOURCE: The kids put refrigerator magnets on the new
THERE IS A STAINLESS SCRATCH REMOVER SOLD BY MOST APPLIANCE STORES / ALSO HOME DEPOT . HAS HAD THIS PRODUCT .. MAKE SURE YOU GO WITH THE GRAIN . OR IT WILL GET WORSE ..MM
Posted on Jul 01, 2010
heatman101
  • 43501 Answers
SOURCE: my fridge is plugged in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
  • 552 Answers
SOURCE: We have a Whirlpool Gold refrigerator model
Very common issue on this unit, the control on the back is bad, the cam and riser will need to be replaced to fix the door.
Let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
My wife opened the refrig. door and saw a blue flash now all the lights in the refrig side are out and the temp gage indicator lights are out as well.
Blue flash sounds like an electrical short (spark) that blew a fuse or tripped a breaker.
Is the machine running? You need to unplug and check the switch that turns the light on and the lamp socket itself for frayed or broken wires befoe restting breaker or replacing fuse. Once your electrical problem is resolved you can reapply power
Jan 20, 2011 | Whirlpool GS6NBEXR Side by Side...
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
Freezer not freezing on whirlpool side by side fridge. Its a 2001 model... ED0GTQXKQ00
Inside the fresh food compartment near lights is the defrost timer. Turn it clockwise slowly until you hear refrigerator compressor start. If this works, replace the defrost timer. Let me know, Thanks, Sea Breeze
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side refigerrator light stopped working even
1 does the light on the control come on when you open the door ?
2 does the freezer light work?
3 if yes to both then...the control board (light control) is faulty
Dec 16, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
