Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Projection tv has picture, but no sound
How do I reset the sound or try to "fix" this issue
    Genius:
  • 1,030 Answers
No sound can come from three possible things. in setup make sure amplifer is set to internal. 2 your speakers could be blown 3 audio is controled on what is known as small signal board if this is the problem a tech will have to replace it takes special computer interface to replace.
Posted on Dec 06, 2008
RCA tv snowy sound great picture on cable
If sound is ok with a DVD etc connected via a rear input (connect directly to set and not thru a receiver etc) the problem is not the set.
If using a box unplug it and or a receiver for a while and plug back to see if a reboot will allow the issue to be fixed that way.
Jun 11, 2012 | RCA Televison & Video
My rca rear projection tv pt56950 picture goes in and out
I'm sorry that the picture on the TV goes in and out. Please follow the troubleshooting steps and check the operation:
  • Please make sure that the connections are secure and proper.
  • Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
  • Also try connecting the device to a different port in the TV if no other devices are available.
  • If the issue persists, try with a different cable.
  • Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Oct 18, 2011 | RCA Televison & Video
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
I have an RCA T52P52937 projection TV with no sound
1. The sound circuit of the board has a possible weak capacitor or
(RC) resistor/ capacitor circuit that has become weak is not working and your tv unit needs service but without a schematic and a meter you will not be able to determine the malfunctioning component.
Aug 02, 2010 | RCA Televison & Video
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
Rca projection tv sound problem
You could try to get the set fixed but I would say the set is just worn out.
Time to buy a new TV I think (going by the picture above anyway)
Dec 28, 2007 | RCA G27647 27" TV
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
