Question about Sony Playstation 3 (PS3) Console
I bout a new tv hd but the system is on but no pic and no sound
  • 659 Answers
If using the hd cables go back to you standard cables and then go into the setting of the ps3 and change it to what you are going to use for output then it should work no problem.
Posted on Dec 05, 2008
Sanyo DP42849 no picture but has sound
Sounds like an inverter problem. On some of these sets, the inverter and the power supply are on the same board. These boards tend to be quite pricey, $100 + range. I've worked on your particular model with the same problem, and it was a bad inverter/power supply board. I would recommend you get a diagnosis to be sure.
Oct 28, 2012 | Sanyo DP42849 42 in. HDTV
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
Jan 11, 2011 | Samsung Televison & Video
I do not know how to connect to my tv to get a picture
hi here is what you can do try plug red green and blue plugs into phillips it should be color coded and then plug same colors into back of tv colors should match then press tv input until you get pic make sure dvd players is on and playing or you can use s video plug only good for pic you wont get sound you would need to plug in rca for audio and turn tv input to s video or if you have hdmi input all you need is one cord for video and sound and you can get full hd on it if player and tv is both capable so plug it in to hdmi 1 or 2 and turn tv input to hdmil 1 or 2 where ever you plug it in also make sure dvd players is on and playing
Aug 27, 2010 | Philips MCD-735 System
Aquos LCD tv no pic or sound on HD tv
The tuner is one board but I wouldn't suggest anyone but a qualified technician to replace it.
Oct 17, 2009 | Televison & Video
Make my wicked system WICKED. Sound hd issues palit hd4850
try these options:
1. try adjusting the main volume of your digital output(tab) under your hd audio manager.
2. try changing your cable(s).
Jul 06, 2009 | Palit Microsystems RADEON HD4850, PCI...
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
I just bought the yamaha htr 6140 and i am haveing a problem hooking everything up.i getm sound no pic or pic no sound or pic and sound from direct tv hd box and then the dvd player wont have sound or...
http://audio.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy55YW1haGEuY2EvYXYvUERGcy9SZWNlaXZlcnMvMjAwOF9Nb2RlbHMvSFRSNjE0MF9NYW51YWwucGRm&idDeviceType=650&idMfg=55&idProduct=569172
Jun 27, 2008 | Yamaha Audio Players & Recorders
Trying to get Fullscreen HD.
MY TV HAS SOUND BUT NO BIG PICTURE IT HAS A LIL PIC IN THE RIGHT HAND CORNER WHEN U PRESS MENU.
I HAVE MODEL NUMBER VS-50603
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
