Question about Linksys Wireless-G WRT54G Router
Wireless rounter Hi. we are having trouble with our wireless rounter. It is connected and receives the internet, as far as when you plug a hard wire connection into the router you can get the internet off that. It says the signeal strength is at full strength but the status is at limited or no conectivity. We were told that the computer was at fault but have had that one checked and have used another one at the same problem still happens. Is it something wrong with the router or can we do something else, any suggestions would be much appreciated. Thanks from BS
    Problem Solver:
We rang telecom and they helped us re configure the network
Posted on Dec 06, 2008
    Sergeant:
  • 302 Answers
In your address bar type 192.168.1.1 and go into your admin screen. if you have password type it in. Go to wireless tab and look up your security settings
Posted on Dec 05, 2008
Wrt54g rounter internet light not blinking
check the Ethernet wire's connection between your modem and router.
check modem's physical connection.
otherwise reset your router.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 11, 2013 | Linksys Wireless-G WRT54G Router
Linksys Broadband Router Model WRT4G manual
Its wireless router.
When you have any wireless device like a laptop. you may connect wireless router and surf the net or mobile etc
Mar 24, 2008 | Linksys Wireless-G WRT54G Router
The belkin rounter of my dad's laptop was installed without password setting. i tried to set it up on 192.168.2.1 configuration page. i was notified that the rounter will restart again itself...thereafter...
If you can still remember the password that you entered on the configuration page, follow the steps below:
1. In the lower right corner of your screen (near the time and date), right click on the wireless network connection icon, then select view available wireless networks. Or, if your wireless adapter has its own wireless utility, you should see that in the lower right corner of your screen.
2. You should see the router's wireless network name (SSID). By default, the SSID is "belkin54g". Select the SSID and it will prompt you for the network key.
3. The network key is the password that you entered on the router configuration page.
If you cannot remember the password that you entered, follow the steps below.
a. Connect your computer to the router using an ethernet cable.
b. Access the setup page by typing 192.168.2.1 in the address bar.
c. Go to Wireless -> Security. Copy the network key.
d. Then follow steps 1-4 above.
For the MAC computer:
1. From the Airport menu, select the SSID.
4. When asked for a password, enter the network key that you entered on the router.
I hope this helps!
Jun 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Hi my name is tam. I am using the Net gear WGR614 v5 and my laptop is using window 7. But i can't connect to internet via the wireless rounter netgear. The internet light was on but the wifi light is keep...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 23, 2010 | NetGear WGR614 Wireless Router
How to unlock my wireless router
Hi Friend
I hope this will work for you. There is a RESET button on every router. Just push and hold that RESET button for 30 seconds. After that release the button and unplug the power cable from back of the router and wait for another 30 seconds. After that plug it back and wait until the power light becomes solid and steady. Now your router is unlocked.
Enjoy
Regards
Chiranjeet
Dec 23, 2009 | Computers & Internet
Have wireless connection, but can't get online
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Jan 25, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
I need help on trying to get my wireless router to work right . it is not working like it should on my lap top . for the wireless net . so what do i need to do .
dear sir
u have to chek internet connection and rounter settung set yr rounter to DHCP mode and configar yr internet in to router after configar yr laptop need to find yr rounter for that u need to run surch wizard it's automatioc found yr rounter then just pair it it's help u..:)
thanks
please vote
chinmay
Jan 06, 2009 | Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Netgear connection to apple air book
Hi claire,
You will probably need to be more specific here. Are you having trouble getting an Internet connection via plugging your ethernet cable directly into the router, or with wireless?
Does your Netgear router have wireless security enabled? A classic issue with some Apple wireless products is that the Apple notebooks sometimes require a 128-bit WEP key (as opposed to the 64-bit you may be using). Please reply with more detailed information as far as what problems you're experiencing.
Ben
Mar 04, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
