Question about Pioneer VSX-D498 Receiver
Volume control keeps going up and down when I turn down the volum
When I turn the volume down the digital read out doesnt go all the way down it just goes up when i turn it down
Volume Switch (Encoder) needs to be replaced professionally. Desolder the old one properly, and insert/solder the new part. Problem solved. Order part from here:
http://parts.pioneerelectronics.com/model.asp?modelNum=VSXD498
Part number asx7004
Posted on Mar 24, 2009
  • 2 more comments
  • gruber1010 Feb 23, 2011
    This part costs about $20 plus shipping, but generally there is no need to buy a new one. Usually the problem is that the contacts inside the control become dirty and oxidized and all they need is cleaning.
    Here's is how to repair the part:
    Remove the control from the front PCB. You will find four tabs on the front of the control. Put the control in a vice and pry the tabs up with a small precision screwdriver or equivalent. Pull the control apart. You will have three pieces, 1) the metal collar, 2) the plastic shaft with the contact wheel, and 3) the back with the wiper arms. Soak the 3 parts in some type of organic solvent such as mineral spirits, brake cleaner or the like to dissolve and clean off all the grease that you will find. Next clean the contact wheel with a cotton cloth and electronic contact cleaner. Ditto for the back with the wiper arms.
    Put some silicone grease or dielectric grease on the contact wheel and the plastic shaft, and then reassemble, squeezing the tabs back in place with a needle nose pliers. Solder it back on the PCB and it should work good as new.
  • stihl888
    stihl888 May 04, 2014
    Realy good tip Gruber, this worked perfect for me.
  • stihl888
    I might add that theres no need to remove (desolder) the control knob from the board all that's required is to gently pry back the 4 metal tabs to release the control knob.
  • stihl888
    Add a Commentull the knob off and clean up the blackened surface being careful not to remove to much of the silver surface, i think the main problem with my controller was the excess build up of lube inside the case gathering around the contact points. Once clean put the knob back together .
My volume button doesnt work an shows no display when i turn it up and down? Everything else works.
If you have a device like the Nexus 6P or Nexus 9 running stock Android, then these are the steps required to boot into Recovery mode:
  1. Hold down the Power key and select Power off. If the touchscreen is unresponsive, then you can simply keep holding down the Power key for several seconds until the device turns off.
  2. Press and hold the Power key and the Volume down key. You should see the Android mascot on his back, a bunch of information about your device, and Start at the top of the screen.
  3. To navigate through the menu options, you use the Volume up and Volume down keys. The Power key is used to make a selection. Press Volume down twice, and you should see Recovery mode in red up at the top right. Press the Power key to select it.
  4. The white Google logo will pop up followed by the Android mascot on his back again with the words No command underneath.
  5. Press and hold the Power key and the Volume up key for around three seconds, and then let go of the Volume up key, but keep pressing Power.
  6. You should see the Android system recovery options pop up at the top of the screen. Use the Volume keys to highlight the options and the Power key to select the one you want.
Sep 16, 2016 | Audio Players & Recorders
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
My Bluetooth keeps coming on at volume 21 I have to turn it down to 5 every time I get a call then it goes back to volume 21 how can I keep the volume at the same as number 5 seems to be the best volu
It seems you have a DEFAULT position and with that said, your device will always reset to the 21 volume setting. Contact the manufactures customer service personnel to go through the process of re-adjusting the controls.
Dec 01, 2014 | Car Audio & Video
Volume keeps going up and down
Follow the volume control wires back to the board. See if you can see if it runs into an IC. These days sound is often controlled by one of these devices. When they go the sound can go up and down.
Oct 11, 2014 | Audio Players & Recorders
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Harman Kardon AVR 500: randomly accelerates volume levels.
The problem is with the actual eltromechanical element on the volume control, my avr 300 does this as well and I'll let you know the secret to avoiding it. There are small indents on the volume control as you turn it, if you leave it half way between indents, it will periodically start reading volume changes, if you're lucky it will go down, if you're unlucky by the time you've noticed it act up your speakers are blown. When you change the volume, make sure the control rests in an indent and the problem will never crop up again. A simple solution if you're the only one that uses the receiver.
Dec 03, 2008 | Harman Kardon AVR 500 Receiver
Doesnt turn on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | Samsung YP-K3 MP3 Player
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
Pioneer VSX-D498 Receiver Logo
1,692 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
