After installing a programe from the vista software when i switch my laptop on all i get is a blue screen
  • Gav Shaw May 11, 2010
    Sorry I Meant Install :)
    What program did you uninstal? and what is the exact error code that you get on this blue screen?
    The code is required as it relates to the type of Software/Hardware error that's causing the problem.
  • 60 Answers
Hi you might need to go back to basic remove all fresh install
Posted on Dec 05, 2008
Automatic shutdown installing application or another software
Do not install the application any more it is not compatible with your computers Operating System it is to put it in perspective, throwing it back up. So I would make sure it is compatible for your operating system. Otherwise you may cause some damage here. Blue screening if install a bad disk or bad driver. Or software that is not 32 bit or 64 bit depends on what your computer has for a Windows system. What is the program and what is your Windows Operating system Win 7 XP or Vista. What is the model of your laptop. What are you trying to install when this happened to you? John
Apr 16, 2012 | Computers & Internet
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
Blue screen
BSOD? Okay, this is what you do, bash your head on your desk first because you've probably installed or bought Windows Vista. Then, go buy Windows 7 and install it.
Jun 20, 2011 | Computers & Internet
Laptop showing blue screen when it loads
thats the blue screen of death generally its an issue with ur RAM try taking the Ram out n replacing it as maybe connection error if thats no help Replace it with some New RAM n will fix the Problem
Mar 22, 2010 | Computers & Internet
My stilliteA135 after a few minutes brings a blue screen
Check your memory first:
How to diagnose a bad memory stick Yor sticks are located in the modle panel under your laptop
Have you installed any program lately that could have cause your computer to act up?
If you are running Vista you might be interested in this article:
How to downgrade your Toshiba A135 from Vista to XP for performance improvement
Alex
Mar 10, 2009 | Toshiba Satellite A135-S2386 Notebook
Stop: oxooooc1f5
The error "Stop: oxooooc15" is usually caused by the new vista SP1.
Try the following
Start>Programs>Accessories>System Tools>System Restore. Restore you laptop to before you had the problem or error.
You can also try the solution from this article by Microsoft
http://support.microsoft.com/kb/946084/en-us.
Jan 09, 2009 | Acer TravelMate 5520 Notebook
Hung, rebooted,shows purple screen on vista desktop
can you give additional information? the purple screen could also be the dreade BLUE SCREEN OF DEATH. do get to see any error message or stop code? can you try to boot using LAST KNOW GOOD CONFIGURATION? by pressing F8 when your computer starts and in the advance boot menu select LAST KNOWN GOOD CONFIGURATION.
normally vista will repair itself when you restart it. was vista able to repair the OS?
Blue screen can be caused by several factors it could be both hardware and software. for software it could be caused by any new software/program installed or updates installed. for hardware it could be from your hard drive to memory depending on the error message. but at this point we shall presume it to be caused by a software and could have corrupted your vista file or hive of our vista.
first option is if you can still go tosafe mode try to do a system restore click start>all programs>accessories>system tools>system restore and choose a highlighted date on the calendar to the left when your computer works well and restore your computer to that date
if you are still having problem get your vista cd ready we may need to fix some files in your computer
boot to cd with your vista inside your cd rom drive. let your windows load up and when you get to see the window welcome setup screen choose repair then type chkdsk /r
still lots to be done but for now let us assume one of the fixes is within this reply
Jun 20, 2008 | Computers & Internet
Blue Tooth
Franc, was the bluetooth adapter working after upgrading from XP to Vista Basic?
It's Bluetooth driver may not be properly loaded. You may try these steps in reinstalling the driver.
  1. Click Start , Control Panel , then Add or Remove Programs . You may also uninstall it from the Device Manager if you cannot find it on Add/Remove Programs.
  2. From the list, Click Remove next to the Microsoft Bluetooth Drivers.
  3. Once the drivers have been removed, click Start , Help and Support then Update Software & Drivers .
  4. When prompted, click System Health Check . When presented with a listing of Updates for Driver, Bios and Software, select HP Bluetooth software .
  5. Follow the prompts to install the software.
Source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300140&cc=us&lc=en&dlc=en&product=95516
May 04, 2008 | Compaq Presario 700 470024-192 Notebook
HP dv9740us back screen of death
Hi.I read ur problem.I thing mysql is not supported vista.U have to search latest mysql software from the Internet.Before installing new software,u have to remove old one and check the RAM capacity.
Feb 25, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
