Sounds like the=> 67006531 Dual Water Control Valve has become weak and when trying to remain open so the water will flow to the water dispenser has began to vibrate and cause this noise. Usally when this happens the water control valve is failing and most times will stop working. Pull refrigerator away from wall and have someone feel the control valve while someone else presses the dispense water switch to confirm that the valve is shaking before replacing. Anyway this is the part number=> 67006531 for your model ASD2625KEB
I will be here should you have questions, Thanks Sea Breeze
