Question about Photography
I need a back door for a SIGMA SA-7 ...
The lock broke and the door won't stay closed. I need a parts list or a manual to find the part number so I can order a new one.
  • 44 Answers
C.R.I.S. Camera Services, http://criscam.com/, is the Sigma parts distributor. They should be able to help you identifying and ordering the proper parts for your camera
Posted on Dec 12, 2008
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Damper won't close
Depending on the correct model number found inside the fresh food section will help diagnose but it sounds like either a defective temperature sensor or the damper itself is the cause. If your model number is a USA model number I can look up what part number and tell you better by looking at parts manual. Let me know the model number and I will try to help you find the correct parts, Thanks Sea Breeze
Sep 15, 2012 | Electrolux Refrigerators
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
Whirlpool duet we broke the catch that holds door closed on washe
If you are referring to the door latch mechanism on the door facing, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
If you are referring to the catch on the door itself, it can also be replaced. Just remove the two Torx (T-2) screws that hold it in place and remove. Replace as necessary with a new catch. Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If the model number is correct, the part number for the door latch is 8182634. The door catch part number is 8181651. You can view these parts under the "Door and Latch Parts" heading as items 7 and 9.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you turn on a sigma SA-7n film camera??
I don't know about the SA-7, but the SA-5 doesn't have an on/off switch as such. Pressing the shutter button halfway activates the autofocus and turns on the light meter. The camera switches off after six seconds of inactivity to conserve batteries, though the shutter can still be released accidentally. Turning the mode dial to the "L" position will lock the shutter and prevent accidental release.
You can find a manual for the SA-5 at http://www.butkus.org/chinon/sigma.htm . It's not ideal, but it should help you get started.
Dec 25, 2009 | Sigma SA-7 35mm SLR Camera
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Fagor Dishwashers
Sigma sa-7
Not a perfect solution, but you can get a free (but a contribution accepted) manual for the Sigma SA-5 at http://www.butkus.org/chinon/sigma.htm
Sep 02, 2007 | Sigma SA-7 35mm SLR Camera
Photography Logo
48 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
