Question about Hotpoint RGB528 Gas Kitchen Range
Oven does not work
When i turn the oven on and i press bake and 350 it goes on but then a red ON goes on and the oven does not warm up.
I assume the oven has worked at one point? Does the broil still work?
This is my experience with my White-Westinghouse gas stove:
The igniter bar is toast. There is 1 igniter bar each for the bake and broil (1 on top, 1 below). This is instead of a pilot light. Its an element that heats up to be hot enough to ignite the gas. If it doesn't get hot enough, the gas does not turn on and therefore not heat.
I went to my store and asked about this. "90+% of the time, that's the problem" So I bought a replacement and installed it myself. Problem fixed. Just had to undo a few screws to get at the bar, then connect the new one's wiring under the stove using marettes & some electrical tape, but the rest back together and that was it. I think the part cost me about $60-80 here in Winnipeg a few years ago. But it would've been at least that just for the guy to show up to look at the stove, never mind fixing it.
Posted on Dec 05, 2008
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
Model RBS275PDB12. I had a recent Power Failure. Since the oven has malfunctioned. When placed on bake the preheat timer does not display. At 350, the baking element gets warm. At higher temps the...
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Mar 30, 2017 | Whirlpool RBS275PD Electric Single Oven
I press the bake button, i choose temp Ie:350 degrees, wait until goes up to temp, next thing you know, it shows 350 but the food is not cooking. press cancel, press bake and 350, temp starts to climb from...
More information is required make model, display type LED, or blue neon red light goes out when on temp, without more info cannot help.
johnf1
May 17, 2011 | Ovens
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
I am working on a Maytag Oven Model #MER5555QAW. You turn the oven to 350 deg. It goes immediately to 350 but then the temp goes off. It will not maintain the desired temp. Is this the sensor or the...
So are you saying that the oven does not start at all?The 350 just appears on the display and then pressing enter it disappears?Does it warm at all?If it warms,it is most likely the thermocouple or ASM,both are the same,just varies between makers.If it does not heat at all,it sounds like somehow the temperature setting got switched from F to C somehow,which can happen completely not done by you.Let me know which situation you have and I'll figure it out.Greg
Nov 24, 2010 | Ovens
The bake button is not going on how do i fix it
The bottom element is bad...and not working...
Check out this tip that I wrote about this problem...
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 03, 2010 | Magic Chef CGR3742 Gas Kitchen Range
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
Jan 03, 2009 | Thermador C302U Electric Double Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Hotpoint RGB528 Gas Kitchen Range Logo
319 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
