Kodak Carousel 760H wont advance or reverse
I think I pushed the reverse button while the projector was advanceing and now the projector will not advance or reverse the slide tray. I can hear it try to move the tray but nothing happens. Bought a used 800carousel projector and it won't forward or reverse. Since I am doing a large project, I'd like to be able to do more than process one slide at a time. It's not my carousel nor my stack viewer. Hope you can help.
  • Anonymous Mar 16, 2014
    who will service kodak carousel 760h projector barrie ontario
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
    Scholar:
  • 33 Answers
What's happened is what happens to all that style eventually. There is a small nylon link that has aged and broken in the heart of the mechanism. A very skilled amateur can repair this but it may take a professional. If you are in the USA, start at http://www.kodakparts.com/Pre_1981.html or http://www.fargo-ent.com/kodak.html if you want to try it yourself. It's the same company, basically. If youa re in Canada, go to Doug Banks http://www.photographicrepairs.com/
Posted on Feb 19, 2009
Kodak carousel 760h projector
Dirt or dust accumulation can retard the gear mechanism. If you get Canned Air at WalMart, blow out all open areas and see if you can dislodge the material collected inside.
Mar 25, 2014 | Office Equipment & Supplies
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
KODAK CAROUSEL PROJECT 760H REPAIR
I used to have a KODAK warranty dealer in New Jersey - - not sure how close to you, though...... Comet Camera & Video Repair in Cherry Hill, NJ 08002; 856-857-9250. I am unsure of the current status of this business, as Kodak stopped authorized repairs of slide projectors in 2007. Good Luck!!
Feb 29, 2012 | Kodak Office Equipment & Supplies
My Kodak Carousel 760H projector will not advance or reverse using either the remote or using the "advance" or "reverse" buttons on the unit. I am able to turn the tray manually. Is...
The problem is a plastic "link" that connects a solenoid to the advance mechanism. It gets brittle with age & cracks, yeilding the problem you have. You need to have the "link" replaced.
Oct 27, 2010 | Kodak Office Equipment & Supplies
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
Won't advance or reverse
the kodak projectors need occasional cleaning and lubrication of the mechanism. the grease gets gummy and sometimes siezes the moter as well. take it in to a shop for a good cleaning or, if you're mechanically inclined, you could do it yourself. just remember which screws go where.
Nov 28, 2009 | Kodak Carousel 4600 Slide Projector
My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Oct 21, 2009 | Kodak Office Equipment & Supplies
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
5,462 people viewed this question
k24674
jasbo
jasbo
