LG Fuzzy Logic won't spin
My LG Fuzzy Logic doesn't spin properly anymore. It does the whole wash up until the spin cycle where it doesn't seem to be able to handle the weight of the wet clothes and just sort of throws them around and ends up putting them in a big sopping wet twisted mess.
There are a few things that have happened since the last wash. We had a 10 second power outage, my son threw a small plastic bottle in with the wash and some beads fell off a dress I was washing. All of the beads are accounted for so they are not jammed anywhere.
Are you able to help? Is there anyway to take the lid off the middle agitater to check if something is there?
Many thanks,
Joy
I had the same problem with my machine. so i just jammed the sensor that deactivates the machine when it starts spinning wildly. doing this allows the machine to work it just sounds like its going to blow up for the first two or three spins and then it sorts itself out.
Posted on May 28, 2009
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
I have an LG top loading 6.5kg Fuzzy Logic washing machine (T6515TDPT01). It is 3 months old and has worked fine until now. It won't spin the clothes properly. The tumblers in the bottom of the machine...
Contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 10, 2011 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
Washing Machines Logo
816 people viewed this question
Top Washing Machines Experts
