Question about Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
  • Anonymous Mar 28, 2014
    handle broke off Emerson Instant Hot water Dispenser Model Insinkerator Model Hot 1 - I have new handle, how to instructions on replacement of handle
    Problem Solver:
  • 5 Answers
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Posted on Dec 06, 2008
Instant hot water dispenser spurts
Sounds like the temp is too high, turn down the temp the dial should be on the front of the unit
Jun 02, 2015 | Emerson InSinkErator C1300 Chrome...
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
Insinkerator instant hot water faucet
Insinkerator stainless tank does not have anode rod to protect from rusting. So these water heaters rust out at welds. And must be replaced. And this is frequent problem.
Copy following link for installing under-counter water heater and see manuals for various models available. Non-insinkerator water heaters have anode rod to protect from rusting:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Jul 23, 2013 | Water Heaters
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
2) Add comment and attach photo of leak.
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
I have an insinkerator hot water dispenser with stainless steel tank, and the tank is now leaking. I'm wondering if it can be fixed or needs to be replaced
Replace water heater if tank wall is leaking.
These things have short warranty period.
Stainless steel will theoretically last longer, but steel tank water heaters have replaceable anode rod to prevent rust-out.
http://waterheatertimer.org/Replace-anode-rod.html
Be sure to recycle the old metal.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Oct 29, 2012 | Emerson InSinkErator C1300 Chrome...
Can anyone tell me why my ISE GN1100 Hot tap is spitting when the handle is pulled back to release the water?
Usually happens when the temperature is set too high, check your instruction book and set it to the advised temp. Also the filter in the nozzle may need a clean.
Sep 15, 2012 | In-Sink-Erator InSinkErator F-GN1100SN...
I have a tankles hot water heater. The problem is
this is a problem they didn;t tell any one about, there is a min of 1 gpm that you have to run for it to sence for the unit to come on, if not the unit will not detect the water is even runnig there for will not come on,, as for the kit faucet, it might have a temp control and it may need to have a cartridge change, the water comming from the tankless is nothing like the old tank heater, the water only losses aprox 1 or 2 degree where a tank heater losses almost 5 or more because of the way the cold water is fed into the unit,, thats whay the sprayer works and the faucet doesn't ,, you have control on the sprayer unlike turning the faucet on,,
Jun 17, 2009 | RTO Chronomite S-90I 277v Instant-Flow SR...
Insinkerator instant hot water tank leaking
When you cut the pipe it has to be cut square or it will leak . Try recutting the end of the pipe and then reinserting it. If this doesn't work then the only thing you can do is replace the fitting.
Dec 16, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Mountain Plumbing Mountain The "Little Gourmet" Heating Tank MT641 Logo
2,003 people viewed this question
Top Mountain Plumbing Water Heaters Experts
rpar
Paul Carew
Gene Haynes
Are you a Mountain Plumbing Water Heater Expert? Answer questions, earn points and help others
