I bought a new key board. put the cd in the drive. at the end it does not install. i did a system restore, had to hit f-12 and the keyboard worked until the computer booted up. i have tried 4 key boards already. please help. thanks den
    Scholar:
  • 52 Answers
New keyboard especially the UBS keyboard cannot be use in BIOS or doing boot selection.. you must have an SP2 keyboard to do so.. TY
HOPE I CAN HELP
Posted on Dec 05, 2008
My desktop keep rebooting when i plugged my cd drive.
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 09, 2013 | LG Computers & Internet
My keyboard is not showing in device manager
To install your keyboard or mouse:
  1. Exit Windows and turn off your computer.
  2. Unplug the power cord and modem and network cables.
  3. Disconnect the old keyboard or mouse.
    If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
      If you are installing a PS/2 keyboard, connect the keyboard to the PS/2 keyboard port on the back of your computer.
      1. Connect the power cord and modem and network cables.
      2. Turn on your computer.
        To install the device driver from the Gateway System Restoration Kit:
          1. Start your computer. The Add New Hardware Wizard window opens.
          2. Click Search for the best driver for your device, then click Next. Complete the wizard by repeatedly clicking Next until the wizard tells you that it was unable to detect any devices and that it has installed an unknown device.
          3. Insert Disc 1 of the Gateway System Restoration Kit into the CD or DVD drive. The System Restoration Kit program starts. Go to Step 6.
            - OR -
            If the program does not run automatically, go to the next step.
          1. Click Start, then click Run. The Run dialog box opens.
          2. In the Open text box, type d:\autorun.exe (where d is the drive letter of the CD or DVD drive), then click OK. The System Restoration Kit program starts.
          3. Click the Install Hardware tab.
          4. Click the device driver, then follow the on-screen instructions. Installation is complete. If your keyboard or mouse does not function correctly, see "Troubleshooting".
        1. The keyboard does not work
          bdgreen2.jpgMake sure that the keyboard cable is plugged in correctly.bdgreen2.jpgRemove all extension cables and switchboxesbdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgClean the keyboard by using an aerosol can of air with a narrow, straw-like extension to remove dust and lint trapped under the keys.bdgreen2.jpgTry a keyboard that you know works to make sure that the keyboard port works.bdgreen2.jpgReinstall the keyboard device driver. For more information, see Installing the device driver.
          A keyboard character keeps repeating
          bdgreen2.jpgMake sure that nothing is resting on the keyboard.bdgreen2.jpgMake sure that a key is not stuck. Press each key to loosen a key that might be stuck, then restart your computer.
          Liquid spilled in the keyboard
          bdgreen2.jpgIf you spill liquid on the keyboard, turn off your computer and turn the keyboard upside down. Let the liquid drain, then let the keyboard dry before trying to use it again. If the keyboard does not work after it dries, you may need to replace it.
Jun 30, 2012 | Gateway 7001433 Keyboard
Acer aspire L320 how do I uninstal and reinstal from back up disc
If you have the restore disk from the Acer Factory it is a fairly simple process. Insert the disk into the CD Tray. Restart the Computer. While is restarting continue to push F12 until you get a Boot Menu. Using the Arrow Keys, navigate to CD/DVD Drive. Hit Enter. It will continue to Load. A Screen will show that says push any key to boot from CD. Hit any key on the keyboard at this prompt. It will load and then you can begin the Re installation tasks.
Feb 28, 2011 | Acer Computers & Internet
Keys on my laptop is not working .. ( From Alphabets A to ENTER).... Rest of keys working good.. After Replacement of new keyboard issuse is still persisting.. Please help me out. Gateway Laptop M-6834...
Sounds like a problem with the software in windows. Try finding the cd that came with your keyboard and install it. If it didnt come with a cd then that means windows automatically detects it by itself.
If thats the case then go ahead and do a system restore on the system back to the last date when the keyboard was working properly. Keyboad should work at that point.
If not, try the keyboard on another computer, if it works on another computer then that means windows is corrupted on your computer and you'll need to wipe out the drive and start with a fresh windows install. Also make sure windows is synching with your receiver.
Dec 30, 2009 | Gateway 2520915 Keyboard
Toshiba Tecra Notebook
INstall the hard drive, if the hard drive came with a cd, put the cd in the drive and boot the laptop. When you see it say "boot from cd hit any key" do so and follow the prompts. This software will "initialize" the disc and install for the first time. Once the disc is "officially" installed take the hard drive disc out of the drive and replace it with Operating Disc. Reboot the machine and again look for the "Boot from CD Hit any Key" hit any key and let the system load windows. You only have to hit the key one time when it says "hit any key" even if during the windows install, the system may reboot but it still may need the disc in the drive, if you see the heading "boot from cd hit any key" dont hit any key any more....just let windows finish loading. When windows finally reboots, sometimes up to three times, then you can take the disc out of the drive or take it out if the operating system instructs you to. Good luck, ParrotHead PC Repair
Sep 04, 2009 | Toshiba Tecra 500CDT Notebook
I forgot my password for my laptop dell inspiron 1720
This works with windows XP or Vista-
Windows Vista Repair through DVD Windows Vista comes with a very handy feature from Windows ME days -- System Restore. Vista's System Restore is far more sophisticated than its previous iterations and can be of a real help here. 1. Just pop in the Vista DVD, make sure your BIOS is able to boot (start) from DVD-ROM first.
2. Press any key to boot from DVD when asked.
3. Set the Language to install, Time and currency format and Keyboard or input method
4. Now click Repair your computer, select the operating system that you want to repair, and then click Next.
5. Click System Restore, and then click Next.
6. Click the restore point that was a day before you changed the password, and then click Next.
Doing this will set your computer back in time to the particular date when it was working fine. Don't worry, you won't lose any data -- only that any settings or programs installed after that date will not be accessible anymore. All you've to is re-install and redo any settings that you did.
7. Confirm the disks that you want to restore, and then click Next.
8. Click Finish, and then click Yes when you are prompted.
9. When the System Restore process is complete, hit Restart computer.
10. You can either remove the Windows DVD or just don't hit any key on the keyboard when it asks again to "Press any key." The computer will start much faster if you remove the Vista DVD.
11. After the computer restarts, click Close to confirm that the System Restore process has finished successfully.
12. After you log on with the old password, change the password for the administrator account if you like.
13. This step is most important -- Remember the password this time.
14. Restart the computer to make sure that your new password works fine.
Mar 26, 2009 | Computers & Internet
Computer Key board stopped working
I take it your keyboard was OK until one day it stopped working. Here is what you should try before you mess around with anything else: Do a system restore. You don't say what operating system you have, but you should be able to find it under All Programs>Accessories>system tools>system restore. Restore your computer to an earlier time--like back to when your keyboard was working. Sounds like you installed something that messed your system up!
Feb 07, 2009 | HP Computers & Internet
Stop: c000135 error
If you do not have any important data on teh computer and you computer was purchased after september 2008 you can try the factory restore. NOTE : DOING A REINSTALLATION OR FACTORY RESTORE WILL WIPE OUT ALL DATA AND APPLICATIONS YOU HAVE PUT ON THE SYSTEM.
To do a factory restore follow these steps.
Please power on the system and as soon as you see the Dell logo hold down the CTRL button and hit the F11 button 3 - 4 times. This will bring up the restore options. Hit Restore and follow the positive prompts on the screen.
If it does not work try a reinstalling from the CD.
Follow these steps to do a reinstallation from the CDs.
1. Load the XP CD in the top CD drive and restart.
2. Press F12 as soon as you see Dell Logo.
3. You will get the Boot Device Menu. Select IDE CD-ROM hit enter.
4. When you get the message “Press any key to boot from CD” hit enter immediately.
5. Windows XP Setup screen will appear loading files.
6. When the screen “Welcome to windows” appears.
7. Press ENTER .
8. Press F8 for license screen agreement.
9. Press ESC to install a fresh copy of windows.
10.Select the partition which says C:.
11.Press D to delete, press ENTER and L to confirm.
12.Highlight the Unpartitioned space hit ENTER.
13.Select “Format the Partition using NTFS file system” hit enter.
14. The setup will format the drive and then copy files and restart.
15. After the installation is complete you need to install the drivers and applcations back on the system.
Sep 14, 2008 | Dell Inspiron 5100 Notebook
Notebook problem
obviously a driver error, you may have the drivers on another partition on your hardrive ,in a restore folder maybe, Acer normally have drivers and programme installations somewhere on the hardrive, so you can restore to it's original factory setup. If you do not an option would be to simply go to Acer website and download them. Only other option is to purchase an external USB powered DVD/CD drive if it's not working, although if you haven't got a restore cd it's irrelevant.
Oct 28, 2006 | Acer AS3613WLCI-XPH CM Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
