The part of my pen drive that goes in the computers usb port has just broke off and was still in the computer? can i retreive my data or can it be fixed?
  • 345 Answers
The possibility of fixing a USB drive isn't good. The contacts that connect the USB connectors to the drive itself are very small and very hard to solder. (they are soldered by computer from the factory). I would by more worried about the USB port on the computer that it would still work after you pull the pieces of the connector out of that port.
Good luck.
Posted on Dec 05, 2008
When I insert the USB into the port, the light flashes then goes off and it seems that it is not recognized..
Try a friend's computer or another computer that can read your files. If it doesn't work, then it's a bad pen drive. It should come onto the desktop of any device as an icon.....double click it to open of course.
Jul 07, 2015 | Duracell Du-zp-04g-ca-n3-c Capless Usb 2.0...
Tip
How to recover data from Pen Drive
Pen Drive gives ussignificant convenience in today's business life. However, due to human errorsor other reasons, we often meet embarrassed phenomena of losing Pen Drive data. The following are sometypically cases in our daily business life.b>
Practical cases:
1. Pen drive still contain all data, and the space shows the same likebefore, but all files and folders in the pen drive are changed to shortcut.
Cause:
Your pen drive was attackedby virus
Resolution one:
If you oftenuse Pen Drive to transfer data from one computer to another, make sure thecomputer is well protected. If any computer is not protected against virusattacks, the files and folders in Pen Drive may be gone or just change intoshortcut. If that happens, don't panic, you can still get back lost data, Firstly, remove the virus, connect your Pen Drive to one PC that is protectedwith a good antivirus and then scan it, fix all the virus threats that aredetected by the antivirus, After completing scanning, some of the useful filesor folders may deleted. Secondly, use pen drive data recovery program torecover deleted infected files.
Resolution two:
If you can'tdelete virus in Pen Drive, just format Pen Drive and then use data recoveryprogram to retrieve data.b>
2. When transfer files from Pen Drive to PC, mistakenly removed the PenDrive from USB port and some data lost, or press "format" command during theprocess of using Pen Drive. Sometimes, delete data in Pen Drive in one day andfind it is useful in another day and want to recover them.
Cause:
Human error
Resolution:
The data youonce have saved in your pen drive is real hard to remove completely. Firstthing to do is stop using the Pen Drive as the chances of your data beingoverwritten increase as time goes on. Then choose a perfect data recoveryprogram. There are many Pen Drive data recoveryprogram in the internet. Although Ihaven't tested them one by one, Card Data Recovery is the most popular one inthese days.
Steps to recover data fromPen Drive using Card Data Recovery
1.
Plug the Pen Drive into yourcomputer using USB port;
2.
Download Card Data Recoveryand install it on your computer;
3.
Check whether your Pen Drivedisk display in your computer;
4.
Select your Pen Drive;5. Run Card Data Recovery andcontinue the operation under the interface instruction.b>
on Jul 20, 2011 | Computers & Internet
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
How can I retreive my files from a kingston 4GB DataTraveler
plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Aug 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
May 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
It shows this device can perform faster. the pen drive is slow
this is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
Jul 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My verbatim 4GB flash drive broke. The metal
If the metal piece just came out of the plastic casing, you may try reconnecting it to the computer and see if it would be detected by the computer. If it's detected, back up all the files.
But if the metal piece broke off, sorry but there's no way to fix it.
Now, you may look for a Data Recovery Center near you. The Data Recovery Centers are computer shops or stores that offers data restoration, back up or retrieval.
Hope these helps and have a great day!
Jul 19, 2009 | Electronics - Others
Transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Jun 08, 2009 | Transcend (589307) Media
Computers & Internet Logo
David Payne
David Payne
