Versaworks is displaying the message "waiting for ink filling". I just put in a new yellow cartridge, performed a test print using the test print button on the printer and there was no problem. What should I do?
SOURCE: Install cartridge
I did a master reset and now it will print but the ink level for the yellow cartridge still shows "empty" even though it is a new one but at least it prints for now anyway.
Master Reset:
Turn off printer and unplug.
Hold down "OK" button and "Help" button and plug in at the same time.
Turn on printer and wait for reset to finish.
It worked for me. Hope it works for everyone.
Posted on Oct 08, 2008
nick_helpap
  • 334 Answers
SOURCE: HP Photosmart C6180 printer doesn't
thats why cant use refill on these mess head s up on it i never recomded useing that stuff jams heads to point u cant clean them ok try reg hp ink once see if it fixes it refill stuff is dangeruis to this not mixed the same way hp is to go thorw nozzel after time time of using that refill stuff jams heads up clogs to points no good ok
Posted on Oct 11, 2008
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
  • 9 Answers
SOURCE: Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Posted on Jun 05, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I've encountered an Incorrect Yellow message upon turning on the printer HP2820
The printer would only display messages of functions commonly as ink shortages. For example, color printers with encountering ink shortge would display a message. However, continuing to print would produce least impressive cooration where for multicolored characters tend to appear in yellow. Also, printers with ink malfunctions require inspection of cartridges, ribbons, and compartments for mal alllignments. Readjusting the ink compartments would request performing test print sheets as reallignment check. At which situation, a continued malfunction would be detected as diagnosable by computer popup messages. Refer to the printer user guide. Good luck
Jan 11, 2011 | HP Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
My printer is saying it has ink system failure. How can I fix it?
Hi
Thanks for using FixYa. First disconnect the USB cable from the back of the printer without turning it off. Now remove the cartridges. Wait till the ' Insert Cartridges ' message is displayed on the control panel. Disconnect the power cord from the back of the product. Wait for a minute and then reconnect the power cord. Press the power button if it does not automatically turn on. Replace the cartridges and close the door. On receiving any command to print a test page let it do so. Now reconnect the USB cable to the rear of the product, and then try printing again.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Cannot print in black because yellow cartridge is empty ?
Take the "empty" cartridge out and shake it, and then reinsert it. I did that on my HP 8500 and it worked. The indicator light showed it was full.
Dec 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 will not read new ink cartridge
Excuse me--but I would like hp to have a look at this series and come out with a statement.
I did call someone in computer repair i think he said they cannot fix it (I don't remember that part)--but (this I do recall) that it probably needed a sensor to be replaced.
I have another bone to pick with hp--revealing: I did use the quick set up format and did not watch any dvd s on it if they gave them--
one thing I've guessed from all of this--there are several colors that get used up awfully fast, and yellow is one of them--even when we have our default set for black. double check yourselves: I believe that their nice black is created with yellow and other colors as well as the black cartridge.
Since I cannot say whether this was revealed in any of the handouts or an instructional video, if there was one--I don't know that they didn't tell this outright.
To be truly user friendly--I don't think that sort of information should be so buried that a casual user wouldn't know that.
(Sure it makes what they more impressive if you don't know how they do it, but I'd like to think they want us to choose easily what colors we are using, especially when printing 'black' ink!)
Feb 02, 2008 | HP Photosmart C5180 All-In-One InkJet...
59 people viewed this question
k24674
jasbo
jasbo
