Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Oil on floor underneath washer
I have a little oil or grease on the floor under my washing machine and was wondering if anyone knows how to fix this?
    Scholar:
  • 76 Answers
Jeffnew The oil which you see on the floor is coming from the gear case. The gear case is not repairable and it has to be replaced. If your washer is less than 1 year old do not wait and call Whirlpool - it is under full warranty. If your washer is between 1 to 5 years old, then the part is still under limited manufacturer warranty but you are liable for any trip and labor charges. It could be much over $200.00. If you are handy and willing to save money, you can buy the part for less than $150.00 and replace it yourself. In that case, I can find the best deal for you and help you with step by step instructions. Gendos...post back
Posted on Feb 13, 2007
Grease blobs appear in wash, Maytag washer A211. How do I fix?
Searched for the model on the web and didn't find it. I am assuming that it is an older top load model. Front loaders I don't know about.
Is the grease appearing just in the drum or is there some on the floor underneath. Either way I would say you need to replace the transmission. If you have an old 12-15 yrs washer I would get a new one. The replacement trannys only last a couple of years at best and aren't worth the money to replace $200-300 if your machine is ready to **** out. The only places on a washer that have grease are the clothes you're washing and the transmission. The tranny will mostly leak onto the floor but can sometimes get into the drum.
Dec 30, 2009 | Maytag Washing Machines
Fairly new ge washer spitts out grease/oil from under agitater
Remove the agitator and inspect the upper shaft bearing condition by trying to push the shaft in various directions. It should not be possible to observe movement in a good bearing. If the bearing looks good, then replace the rubber seal just under the plastic block on the shaft top. You must be very careful not to damage the shaft where the seal lip rides. If the bearing is loose, the machine must be torn down to remove the shaft from the supporting post.
Aug 15, 2009 | Washing Machines
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Oil spill under washing machine
Sorry, this could be bad. The transmission might have blown a seal. It's a big job to fix, if this is the problem. It might be time to consider replacing the machine.
Premmy
Oct 21, 2008 | Washing Machines
Oil and black specks on floor underneath washer (middle)
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Jul 21, 2008 | GE WBSR3140DW Top Load Washer
Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Aug 30, 2007 | Kenmore 22642 Top Load Washer
Grease/oil under washer
Hi, there. Get some one to fix that leak ASAP. The lack of oil will ruin your machine's transmission and/or motor. If you've noticed that your machine runs louder than it used to, then ***stop using it*** until you get the leak repaired. I kept using mine and when it stopped working I couldn't get the parts (a transmission) so I have to get a new one.
Nov 30, 2006 | GE WDSR2080D Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
281 people viewed this question
Sal De
Marvin
Marvin
jimorris77
