Question about Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries
Battery charger Where in Gods name does one find the type of battery charger needed for the Kodak easy share Z712 IS???? I've spent hours trying to figure this out and am quite frustrated. I can't find one place to tell me what kind of battery charger to get.
Hello :) pls help ..... HAve a kodak c195 easy share , Used to work fine when downloading pictures . Now everytime i Plug into USB port it shuts off . I have purchased new batteries and tried another...
TAKE THE BATTERIES OUT TURN IT OFF PLUG IT TO A KNEW USB PORT ON YOUR COMPUTER ONE YOU DON`T USUALLY USE THE USB PORT SEND`S 2.0 VOLTS TO OPPERATE DEVICES TURN IT ON WHEN THE CONNECTIONS ARE MADE REFER TO USER MANUAL!?
Aug 30, 2011 | Kodak EasyShare C613 Digital Camera
My kodak easy share m550 cannot turn on unless connected to charger before it can turn on,please need help
There is only one thing that comes to mind: your rechargeable batteries are weak and don't reach the necessary operating voltage, or they could be the wrong type.
You need the Li-Ion type of rechargeables.
Jun 16, 2011 | Kodak EasyShare M550 Digital Camera
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
I Have the Problem with my Easyshare Z712 IS Batteries
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 03, 2009 | Kodak EasyShare Z712 Digital Camera
My kodak easy share z712 IS won't power on, I have used 6 sets of batteries, to no avail. The batteries are new, thinking that was the problem, I bought this refurbished about a year ago, it worked for...
If the camera will not power on at all, then I have no where to start. Nothing can be done except repair. this camera will need repair, or sell it as parts or as is on a site such as Ebay.
Call Kodak, and tell them the problem,it just might be that they may take the camera back. It may be worth the time. Go to the website for kodak, find the support and then find the service or repair department. Call them.
Nov 09, 2009 | Kodak EasyShare M853 Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Battery problem
For my Z712 I'm using since one year CRV3 li-ion rechargeable.
No problems until now, few THOUSANDS of photos.
I've buy it from ebay.co.uk .
Regards.
Oct 06, 2008 | Kodak EasyShare Z712 Digital Camera
Memory card
I just got a used one from a family member (the white one). If you open the battery compartment, there's a little slot that the SD card goes in. It's really easy to overlook, I spend about a half hour trying to figure out where the dumb thing went.
May 31, 2008 | Kodak EasyShare C613 Digital Camera
Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries Logo
43 people viewed this question
Top Duracell Electronics - Others Experts
Craig Butler
Craig Butler
Joseph Mueller
Joseph Mueller
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
