Question about JVC GR-DVM70 Mini DV Digital Camcorder
E04 message At a certain point in playback, the picture stops and I get a flashing E04 message. Also, when I was recording on the same tape the other day, I got the same message. Hmmm, I am going to switch tapes. But I don't have the manuel anymore, and don't know what E04 means. thanks, Lisa
  • Lisa Oswald Feb 09, 2007
    switching tapes didn't work and it sounds like some gears are not moving well
    Sniper:
  • 80 Answers
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Posted on Feb 16, 2007
  • Joseph  Weibel
    Joseph Weibel Feb 16, 2007
    Ooops, I see you tried another tape. If you press play and hold the tape door slightly open without triggering the eject switch, you will see what is causing the shutdown to occur. One or both of the reels are not turning. If the capstan is still turning and the takeup reel is not, then your video tape would be spilling out into the deck, the camera is simply protecting itself and your tape.
    Joe
SOURCE:
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Beeping c:31:23
I bought a new handycam that has no tape it recirds in Mini-DVD disks or a memory card. I just got fed up with tapes. Thanks.
Jan 23, 2009 | Video Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
NO picture - JVC GR D74
JVC GR-DVL9500
Error Code E04 when I load a tape .
Oct 04, 2007 | Video Cameras
JVC GR-DVM70 Mini DV Digital Camcorder Logo
942 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
