Question about Sandia Plastics Super Hipster Power Hepa Canister Vacuum
Hoover Empower Widepath, brush won't spin.
The brush only spins when the weight of the vacuum is lifted, and when the brush is not spinning, in the "ready to vaccum position", it starts to smell.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Posted on Nov 20, 2009
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Pump assembly
This model does not have a pump. The water flows from the tank by gravity when the trigger is depressed. A turbine assembly spins by the airflow which causes the brushes to spin
Oct 04, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
My brushes on my Hoover Steam Vac stopped spinning again! I took the brushes out and they turn fine, but when inserted back into the base, they do not turn, AGAIN! Anyone know what the problem is and...
Tip is slightly, do the brushes spin then? If so, then the brushes are air driven. By the spin indicator at the front of the machine, you'll see a small screen (same type of thing as is in your dryer), scrape it, you'll probably find there's a build-up of fluff. Clean off the fluff, and try again.
Nov 01, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
Brush attachment stops spinning
does the pin break or the turbine freeze
Dec 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My spin scrub brushes don't spin at all.
Check that the belt that spins the brushes is not broken, also that the
gear that drives the belt is turning.
Tom
Aug 10, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Sandia Plastics Super Hipster Power Hepa Canister Vacuum Logo
337 people viewed this question
Top Sandia Plastics Vacuums Experts
JoeVacs
Are you a Sandia Plastics Vacuum Expert? Answer questions, earn points and help others
