Question about JVC HD-52G786 52" Rear Projection HDTV
Qustion about a JVC DLP set. Please help!
Hello i have a JVC model # HD56G786 DLP TV. The problem i have is that the set will not turn on. Whe i try to boot the set up it starts as normal as the blue power light stays on and the small red lamp/program led blinks slowly,but after a few seconds the blue power light goes out and the red lamp/program light begins to blink rapidly. I have checked the lamp and it is good. I have a feeling it is in the power supply board but there is no visible damage to any of the components on the board so I am not sure which component is bad if it is the power suppy board at all. all help on possible fixes for this would be great. not sure if this a common issue but if it is it hopefully will be an easy fix.
  • jason May 11, 2010
    you can look for signs of possible faults on the solder side of the board and look for bad solder connections in heated components areas , then if that looks good start looking for voltage problems
    if there is suspected solder connections or browned areas or even if there is not then check the components in the power out area , if you can check components values then you are going to have to check suspected stages in the powering up and stanby circuits
    components like voltage regulators , ic's that heat up , any component that disapates heat can be a suspect and those that do disapate heat that are not supposed to are definately faulty ,like disk caps and small resistors
    but you would need to measure some components values , voltage readings and a visual of the solder side of the board to be able to start eliminating possible causes
    can you give some test results?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sorry but there could be a number of possibilities and the best diagnosis would be to perform voltage checks of critical boards and compare with known readings. Common problems could be as simple as cold solder or loose connections, thermal fuse of the cooling fan or the light engine in some models not necessarily what you have.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
Posted on Dec 05, 2008
My 52" Projection JVC TV
Hi:
I could help u more if you give me the complete model number of your television. Without the model I do not know what Were working with.
Thanks..
Apr 22, 2011 | JVC Televison & Video
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Hello i have a JVC model # HD56G786 DLP TV. The problem i have is that the set will not turn on. Whe i try to boot the set up it starts as normal as the blue power light stays on and the small red...
I would agree with you on that the power board could be at fault. The best course of action would be to get the board/TV checked out professionally. It could be the dry joints, resistors or capacitors.
Dec 04, 2008 | Televison & Video
MY JVC HD56G786 TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC tv model HD56G786
It's easy, you just have to go back into the menu setup for the auto channel/tuner setup and rescan for channels. I'd noticed this as well when playing around with the tv when I'd bought it and it had done the same to me.
Dec 10, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Tv problem jvc hd56g786
your lamp bulb is probably finished so get a new lamp bulb they are easy to replace just look for a small panel on the side of you tv all you need is a flat head screw driver to open the panel and you should be able to pull out the lamp bulb
Oct 14, 2007 | JVC HD-52G786 52" Rear Projection HDTV
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC HD-52G786 52" Rear Projection HDTV Logo
396 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
