Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero 550 Gurgling whenever door closes
Whenever we close refrigerator door we here gurgling of water somewhere low in the refrigerator or above the freezer
We do not have a water line running to the freezer and do not have an ice maker
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Personally it does not bother me that much on mine. But since you asked, there is drain line that runs into the drip tray underneath. The line should not have any bends in it to form a P-trap which will hold enough water in to form a seal, so when the door closes and the pressures equal you have a gurgling sound. If it really bothers youtry these steps, remove the kick plate by removing the two phillips head screws on either side. The drip pan is suspended in the middle of the support and will probably have water in the drip pan so put a towel down before you start. Once off shine a light to see if the tube has a bend in it. Depending on when it was made there may be a clamp that hold the drain tube in place. Carefully pull the hose past that clamp to remove sag and eliminate the bend which forms the P-trap. You have to be careful as the hose maybe brittle and come apart. So if you pull to hard you may wind up replacing that line which requires pulling the unit at considerable cost. There is a check valve that can be ordered but was only used for a short time. The inline check valve was a part number 4202130. If it bothers you too much and don't want to try the fix here is the Sub Zero locator page for parts and service. http://www.subzero.com/locator/locator.aspx?type=0&zip=02030
Posted on Dec 05, 2008
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
LG refrigerator noise sound.
This is under warranty call for repairs.
Jul 10, 2013 | Refrigerators
I couldn't find my model so I just picked one. I have a Kenmore Coldspot side by side. Model 405.58404800. I have been getting a gurgling sound the last couple of days when I close the freezer. It...
not a motor just the fan the defrost drain tube gurgling when you opening the door their is so much vacum that its sucking air ththrew the defrost water drain located in back of refrigerator their is a kit you can order drain gurgle kit
Jan 27, 2011 | Kenmore 52282 / 52284 Side by Side...
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
When I open and close the freezer door there is a gurgling sound
The gurgling sound , is the vacuum being pulled thru the defrost drain line . Like when you close a freezer door , and you see the gasket being pulled in tighter . This gurgling , is the drain p trap with a vacuum being pulled thru it . Normal .
Sep 25, 2009 | Kenmore Refrigerators
Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
Subzero gurgling sound
Personally it does not bother me that much on mine. But since you asked, there is drain line that runs into the drip tray underneath. The line should not have any bends in it to form a P-trap which will hold enough water in to form a seal, so when the door closes and the pressures equal you have a gurgling sound. If it really bothers you try these steps, remove the kick plate by removing the two phillips head screws on either side. The drip pan is suspended in the middle of the support and will probably have water in the drip pan so put a towel down before you start. Once off shine a light to see if the drain tube located 2/3rd the way back in the center andh is 1/2 inch in diameter made of clear plastic w/white band reinforcing it, has a bend in it. Depending on when it was made there may be a clamp that hold the drain tube in place. Carefully pull the hose past that clamp to remove sag and eliminate the bend which forms the P-trap. You have to be careful as the hose maybe brittle and come apart. So if you pull to hard you may wind up replacing that line which requires pulling the unit at considerable cost. There is a check valve that can be ordered but was only used for a short time. The inline check valve was a part number 4202130. If it bothers you too much and don't want to try the fix here is the Sub Zero locator page for parts and service. http://www.subzero.com/locator/locator
Nov 09, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Sep 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
519 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
