Question about Kenwood KAC-9152D Car Audio Amplifier
Power on amp switch off when base is turned up
Hi ive got this kenwood kac 9152 1800 watts amp , when i have the amp turned up performing average to high base 30 secs later the amps powers off and about a min later it turns it self back on what may be causing this
  • 21 Answers
Your problem is that the transistors on the circuit board are shorting out on the back panel of the case. is the amp connected to the sub box? its caused by the vibrations through the box and amp. take off the back cover and look for some scorch marks, if there is any, find the leads on the circuit board that are causing it and bend them down a bit. i had the same problem with my amp, and so have many other people. this fixed my Kenwood 9152D, and it has worked fine for many years after using this solution. if anyone has this problem and needs help with fixing it, email me at thadoggma420@hotmail.com
Sam
Posted on Feb 13, 2009
A: make sure that speakers size and watts.B: Type of speakers is used for base. C: Make sure the current (Amps)of the battery and your amplifier. D: Check audio from source and decrease the level of base. Thanks.
Posted on Feb 09, 2007
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
I need an appropriate speaker for my kenwood amplifier kac-5202
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Jun 12, 2011 | Kenwood KAC-5202 Car Amp
I dont no how many watt my amp has
Hi and welcome to FixYa,
To my understanding, a Kenwood KAC-628 is rated with max power of 100 watts X 2 at 4 ohms per channel. Incidentally, it is bridgeable resulting to 300watts X 1.
Good luck and thank you for asking FixYa.
Dec 23, 2009 | Kenwood Car Audio & Video
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
211 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
