Question about Sylvania 6432GG 32" TV
How to run channel auto scan
Hi, i just purchased an Insignia flat screen tv and hooked it up to my cable box. The first screen says "please run channel auto scan". How do I do this? Is this something on the TV remote or cable remote?
  • 4 more comments
  • meganschuck Jan 18, 2009
    I have the same problem however we ran the channel auto scan but then nothing happened.
    Did yours work?
  • messy1303 Mar 03, 2009
    I have the same problem...but I keep scanning and it does not go away. I have scanned a hundred times but its still there..what do I do?
  • Anonymous May 16, 2009
    The channel scan menu is gone! There's nothing under setup.
  • Lauren Austin
    Lauren Austin Dec 21, 2013
    the same thing keeps happening to me, everytime i run the scan it just goes right back to it and says "please run autoscan"
  • Lauren Austin
    Mine keeps doing the same thing, i have ran the channel scan prbably 50 times and nothing happens.
  • mintvl Mar 16, 2019
    Make sure you have a Antenna plugged into the back as well
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
  • unique_chin
    unique_chin Sep 04, 2012
    thanks so much - maleek from bk
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
If you press the input button on the upper right side of your remote, it will give you a drop down menu. if you remember which hdmi slot you plugged your cable into, choose that and then your t.v. will work.
In my case I have a cable box that is hooked into the system. I had to turn the cable box off and then when I turned it back on viola! a beautiful picture awaited me.
good luck
Posted on Jan 12, 2010
  • 1 more comment
  • hgfvghgb1234 Dec 16, 2010
    ugrhhh you all are stupid i just want my dvd player to plug into my tv so i can watch MY MOVIES!!!!! not cable! ahhhhhhhhhhhhhhhhhhhhhhhhhhh!
  • Samirocks01 Jan 28, 2012
    You people are dumb Maby I want to fix my computer duuu!!!!!
  • Joe Jameson Feb 12, 2013
    Thank you, I tried everything and your solution worked.
What does "please run auto scan" mean and how do I do it?
Posted on Sep 22, 2012
    New Friend:
If that is showing on your TV, surely your TV is not on the correct input. Check what cables you have connected at the back of your TV. If they are the RCA composite cables (red, yellow, white); your input should either be VIDEO or AV. If you're using a component cable (red, green and blue), input should be COMPONENT. And if you are using an HDMI cable, input should be HDMI. Just look for an INPUT button on your TV remote or SOURCE.
Posted on Jun 14, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
You should be able to press the ok button on the remote and then it should start doing the scan. If not then press menu on the remote and in settings the should be a auto scan.
Posted on Mar 16, 2019
    New Friend:
TRYING TO TURN THE AUTO SCAN OFF BUT THERE IS NOTHING TO CUT IT OFF. ALSO, I HAVE A SALLITE BOX NOT CABLE. THE FEED SHOULD COME THROUGH BUT IT DOESN'T.
Posted on Feb 23, 2016
    New Friend:
I had to set TV back to HDTV.
Press 'source' then set to HDTV, then exit by pressing 'menu.
That worked for me.
Posted on Jul 02, 2014
    Scholar:
  • 111 Answers
More than likely it's on your TV remote, I would consult my manual it should say how to do it.
Hope this helps
Posted on Dec 04, 2008
SOURCE:
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
It ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
Aug 26, 2012 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
Insignia channel auto scan
If its cable and requires a box the set will have to be on a specific channel---if directly from wall etc go into set menu and make sure it is set to CATV or cable----if in air or antenna it will not save channels.
Jun 13, 2012 | Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Initiation
Yoiu should be using the video output signal from your satellite box, not RF cable, to get the full benefit of HD program to feed the video input of your TV. Please resd the instruction book on how to hook up satellite setup.
Nov 07, 2009 | Insignia LCDTV26 26 in. Television
I just got cable and I cant get the channels to come in as cable channels. I lost my manual and have a universal remote?
Hi gail dahl,
I am happy to help.
From the Video Menu the Tuning Band must be set to Cable and not to AIR or Antenna. You will nee to run Auto Scan for channels from the Menu also.
I have provided a link to download the manual. http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL40XBR2&LOC=3
Let me know if you need further assistance and please rate this solution. FixYa.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 31, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sylvania 6432GG 32" TV Logo
40,040 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
