HOW TO DEACTIVAT RADIO FROM THEFTLOCK SATE.. OR HOW TO REMOVE THEFTLOCK COMPLETELY FROM MY CD RADIO PLAYER.. 2004 PONTIAC GRAND PRIX 3.4 LTR GT2 SEDAN VIN# 2G2WS522841149934 Theftlock(R) Radio Anti-Theft System
SOURCE: Anti-theft code 1995 Pontiac Grand Prix
DO a google search for Radio lock codes with you make model vehicle,, for 7$ you can get it,,here is what I found for a 2000 gp..
1. Press and hold presets 2 and 3 for about 7 seconds until you get 3 digits on your display. This is the first 3 digits you will need, so write them down.
2. Press the AM/FM button to get the last 3 of the 6 numbers you will need. You only have 5 seconds to do this. If you wait too long before pressing the AM/FM button, the display will go back to LOC. If this is the case, just start over at step 1.
3. Call 1-800-537-5140, press 2 for Pontiac, press 620529 and hit the # key. The computerized voice will ask you for your 6 digit code you have written down. Enter that and press the * key. He will then give you your unlock code, and the option to get additional codes. The first one worked for me so do not worry about the additional ones.
4. Set the code into your radio by pressing the hour set button on your radio until it corresponds with the first 2 digits of your code, then press the minute set button until the last 2 digits of your code are entered. Immediately press the AM/FM button once the correct code is entered and the code SEC or "secured" will be displayed. This part of the procedure is outlined in your owners manual.
5. If you want, you can change your code so you will not forget it, or get rid of the theftlock all together. These procedures are outlined in your owners manual, read it if you would like to change these values.
6. turn on the power to your radio and enjoy.
Hints:
- The first 3 and the last 3 digits were the same on my radio. (for example first 3 were 123 and last 3 were 123) First I thought I was doing something wrong when the display wasn't changing, but I wasn't. Just to let you know it is a possibility.
- The dealer code 620529 is an actual dealer. If GM finds out that this code was leaked to the public, they will remove it from their system. If the dealer code does not work when you phone the 1-800 number, you can search for a new dealer code on the internet somewhere. If this does happen, PM me and I will try to find one that works for you.
gaframe = true;
'' + google_ads[i].line1 + '
'' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
google_ads[i].visible_url + '
var adsByGoogleRight = "-40px";
if(dartRecieved){
document.getElementById("ga_300x250").style.clear="both";
document.getElementById("ga_300x250").style.left = "0px";
document.getElementById("inner_adv_caption").style.display = "block";
document.getElementById("ga_300x250").style.width = "370px";
adsByGoogleRight = "5px";
else if(isHealthinationExist){
var healthinationBox = $('healthonationBox');
if(healthinationBox){
var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight;
var ga_top =getObjXY(document.getElementById("ga_300x250"))[1];
if(ga_top-helthinationBot >0){
document.getElementById("ga_300x250").style.width = "530px";
else{
document.getElementById("ga_300x250").style.width = "410px";
$('boxAdWrapper').style.display = "none";
else{
//add "ads by google"
var logo_img = '';
s += '' + logo_img + '';
document.getElementById("ga_300x250").innerHTML = s;
var currl = $('related_links');
var currq = $('related_questions');
if(currl!=null && currq!=null){
var currltop = getObjXY(currl)[1];
if(currltop > rltop )
currq.style.clear="left";
return;
SOURCE: charging system failure
Hello! The problem you are experiencing is most likely due to a fautly or malfunctioning alternator. You can take the car to any major auto parts store, and they can do a FREE charging system test which will tell you if your alternator is operating (and charging the battery) properly, as well as if your battery is accepting the incoming charge from the alternator.
Hope this helps and good luck!
SOURCE: 1996 Pontiac Grand AM V6 Anti-Theft Activated
this is easy fix i had same thing happen when you start your car and it dies don't touch your key for no less than 11 min then turn it to off for no less than 30 sec the book says you might have to repeat this 4 times it worked the first time for me
SOURCE: i want to install a
Under the steering wheel by your feet, remove the 2 screws that hold the panel up. Carefully remove that, then just take your hands and start popping the dash off, but be CAREFUL!
SOURCE: anti theft lock on pontiac grand am need code!!
on most hondas you have to pull the radio and get the code of the back then call the dealer, however I am pretty sure on that car you just write down the vin number and call the dealer I emphasize on call so they dont charge you
