Question about Whirlpool GT1195SH Microwave Oven
Electrolux microwave PLMB 209DCA sparks through the magnetron window into the oven. I tried a replacement magnetron and it did the same thing. Could this be a defective capacitor or transformer?
  • nukesub2 Dec 13, 2008
    The problem was fixed when I applied a recommended solution by another website "microwave troubleshooting" . It pointed out that food splattered on or near the wave guide window would carborize if not cleaned up. Carbon is an excellent conductor and the magnetron will arc over to the carborized food spot. When I cleaned the waveguide and removed the mica "window" the problem was fixed. I recommend to your experts that the first thing to look for when there is a report of sparks from the waveguide window is food spatters on the window or in the waveguide. Even though my magnetron was partially melted on the output nozzle
    it works OK now, but the cleaning has to be thorough and any discolored metal on the waveguide must be sanded to bare metal., While awaitng a new mica "window" it is ok to use the microwave but cover all food to insure no more splatters.
No solution yet but have ordered a replacement high voltage capacitor. If this works, I'll let you know.
Your expert did not respond to one of my questions which was whether he had experience with this type of problem with a microwave magnetron. When he did not reply after a substantial period, I assumed he had given up on the problem.
Posted on Dec 05, 2008
Massive sparking and noisy when switched on to heat
There are 2 things that cause the massive sparking:
1. you placed inside the microwave oven a metal plate or one with silvery or golden drawings;
2. the mica sheet that covers the magnetron window is compromised (has holes, it is cracked) or it is covered with burnt (carbonised) food.
You have to carefully inspect the mica sheet and wash or replace it, if necessary. Hope that helps.
Regards,
Dan
Oct 10, 2016 | Microwave Ovens
How much is a magnetron?
Good Morning Friend,
I understand you are looking for the price of a magnetron, part number 5304467693, for your Electrolux microwave, model# EI30SM55JS. The cost of the magnetron is $89.97 plus tax and shipping. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area. . I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux EI30SM55JS Microwave Ovens
318279620a electrolux I need to replace my
When you say stays on , is the magnetron still running ? The door switches need replacement or cleaning or timing went out.
Oct 14, 2013 | Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
When I use my microwave, it seems it was spark happening when I use it. I'm afraid to test it again. Please tell me how I should know it's safe to use
2 things cause sparks.... a damaged Waveguide RF window or bare metal inside the cooking area. If you note bare metal you can sand and paint it with an appliance enamel paint. (no lead paint!) Just make sure to only sand the area your painting as any sanding scuffs not painted will hasten a repeat performance of the sparking routine. The RF will bounce off bare metal and cause the sparking. Once PROPERLY painted it no longer sparks.
If it is coming from the area of the Waveguide RF window... Make sure the window is replaced before next use.
Thanks for choosing FixYa,
Kelly
Apr 21, 2011 | Frigidaire Model PLMVZ169GC Microwave Oven
The microwave turns on, the turnstile turns but the food does not heat up
This is caused by one of two problems, the most likely more common is a bad magnetron, or the high voltage transformer that drives the magnetron is defective. To repair either issue would not be cost effective "more costly" replacement "best option"
Jan 16, 2011 | Electrolux ICON Built-In Microwave Oven
I have an Electrolux CPLMV169DXCE built in microwave and everything works except it does not heat
The magnetron circuit, the part that generates the microwaves has failed. Often the part shorts out and needs to be replaced. However the part can cost almost as much as new oven, get some estimates before deciding whether to repair or replace.
Dec 07, 2010 | Electrolux Microwave Ovens
The magnetron end of my microwave oven is damaged
The magnetron probe - antenna covering might have got damaged.Due to the presence of low quantity of food, the back power to the magnetron has led to the spark,there will be a light damage and it wont affect the working of the oven any time in the near future as long as this mistake is not repeated.If the oven is under warranty period its better to get the magnetron replaced:) if not, this is not a major concern.
Jan 25, 2010 | GE JVM1870 Microwave Oven
Does not even get hot enough to pop popcorn
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 04, 2009 | Electrolux E30MO65GSS Convection Microwave...
Whirlpool GT1195SH Microwave Oven Logo
369 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
