Question about Konica Minolta DiMAGE Z5 Digital Camera
HELP!!!!! I have a dimage Z5 and the lense is stuck. It is zoomed all the way out and won't come back in! The focus is zoomed to the max as well and it iwll focus at this point but everything is way close up. Please help. To send it back to Sony is atleast a min. of $181..... The camera is almost 2 years old and I have babied it to death! Thanks.
  • 3 more comments
  • Jodie *** Feb 16, 2007
    Yes, the barrel will stay fully extended when you shut it down, most of the time anyways. When you power the camera on it will zoom in and out and back out. It is kind of like it hasgone crazy. But the focal view is fully zoomed, when you try and move the little zoom switch in and out on the side it doesn't "un"zoom. Does this make any sense to you?
    Great comments onthat site. Thanks.....
  • ninashiela Nov 04, 2007
    I have the same problem with Jodie, my Konica Dimage z5 lens is stuck. even if i turn it off it wont move in, if i turned it on it will only moved in and out again and if i look on the viewfinder/LCD everything is zoomed out. can you anyone help me?
    yeah i have the same problem is there anymore solutions?
  • jevvyj Nov 14, 2007
    lenz does not retract when switching off also out of focus lenz acc off
Does the barrel fully retract when the camera is shut down? I suspect a mechanical problem... If you're not very technical, I do not recommend opening it up... Try whapping the objective a little. I'm not kidding; the problem may be caused by some gears that got stuck... Otherwise, it could be quite hairy because the zoom motor or its controlling electronics could have gone bad...
Posted on Feb 16, 2007
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Sep 30, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
80-400 NIkon won't zoom on NIkon D700
Not if your other lenses work ok. I would contact the Nikon Repair Depot that cleaned it.
Jun 20, 2012 | Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR...
Faulty zoom
try to reset factory setting
Sep 18, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
When inserting SD Card in to Dimage Z5 the camera will not read card. (''Unable to use card.) Please help.
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z5/compatibility/detail.html
Your card is probably not supported by the camera.
Jul 05, 2009 | Cameras
SD max size
I don't have any first-hand information, but you'll probably be ok as long as you stay under capacities of 2GB. The original SD specification only allowed cards up to 2GB to be compliant with the standard, so I think that pretty much every camera that has an SD slot can handle 2GB capacities.
Jan 25, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Same SD card problem with Dimage Z5
Your Card may need to be formatted. to fix this problem:
[note- before you start, make sure that your SD Card is blank, or that the information is unimportant, because formatting your card will erase all of the information.]
1) Plug the card into your computer, if you can, in the SD slot, or use a USB - SD transformer to plug your card into a USB port.
2) After its plugged in, go to 'My Computer'.
3) Right Click on the drive its plugged it into
4) press format
5) Make sure all of the correct settings are on and start the format.
now your SD card is formatted and should work in your camera and you can continue taking pictures. YEA :^)
Apr 13, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
175 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
