Question about IBM ThinkPad 570E Notebook
Windows problem i can not add windows to harddisk,my usb slot is not can i resolve that?can i do that whit a rack on other pc's?
  • Nicolas
    Nicolas May 11, 2010
    Are u trying to instal windows via the usb?
    Dont you have an cd/dvd driver?
  • 177 Answers
An ultraport is a good solution to this and many other future similar problems. I just bought two on ebay this week, one for work & one for home, both for under $60
Posted on Sep 06, 2009
  • 302 Answers
Download the drivers from the manufacture of the pc
Posted on Dec 05, 2008
My harddisk , seagates replica single PC unable to detect all of the sudden.... it shows that the window unable to install the driver.. hope to find a solution cause all my backup data inside..
Hi t_c_low2005 ,
First of all , please do not panic,
Nothing would happen to your data unless you deleted it intentionally or your hard disk has suffered a hardware damage.
I would recommend you to check if you have an extension wires for USB connected , if yes then remove them and connect the hard disk directly to the USB slots on your motherboard.
This should work fine...:) Hope it helps.
May 09, 2011 | Seagate Replica 250 GB USB 2.0 Complete...
Hi i have a verbatim usb harddisk whit 1tb and the usb is 2.0 but my laptop can't find the device and my windows is xp sow can jou help me greetings Zicko hoek
If your drive came with any drivers be sure to install them.
Also note that the Store N Go 97538 is a USB 3.0 HDD. You will require a USB 3.0 port in order to use it.
More info here:
Feb 28, 2011 | Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5...
My acer ferrari, 2gb ram, windows 7, 320 gb harddisk (WD), BIOS 3A28, sees only 128 gb of harddisk. how to resolve this?
Hi Martin.
This is Suresh.
It seems our chat session was disconnected.
Please get back to chat, so that I can continue to work on the issue.
Sep 11, 2010 | Acer Ferrari 3200 Notebook
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
USB card installed on AcerPower FE
Did you make sure its in the correct slot in the motherboard. Turn off computer remove card from slot turn on computer re insert card and see if windows plug & play system recognizes it. the usb slots in the machine are already recognized. Check if the Add hardware app is running before inserting the new usb hardware.
Jul 09, 2009 | AcerPower FE PC Desktop
Need a Hard Drive and cable for the jensen NVX3008PC ,where could i find parts
As it has USB port, please buy a USB portable Harddisk, You can add High capacity memory cards too.
You can do these if you wish to expand the storage of the device.
I am actually not sure..if you are asking about the internal HDD to change .
Apr 21, 2009 | Audiovox Jensen NVX-3000PC 7 Windows XP...
Harddisk data not acceseble
please give some more details on the machine and OS u are using, sounds like you have got windows installed and the external harddisk is being recognized as an unknown hardware device.
you may face following problems:
- either you need special drivers for it suiting to the windows version u are using(google!)
- or your PC still has only the 1.1 USB ability
but the external hd is 2.0 USB and that's producing trouble
in windows XXX:
-make sure you are logged in as an administrator
-then you may try to find the harddisk using the windows explorer or
-left-click'start' goto 'system' then 'hardware'. double-click now and perform a search for new hardware
- does windows find the harddisk now?
- let it install the drivers, unplug usb-device, reboot, reconnect and now it can be found like any other harddrive
good luck - if still facing the problem, please post another request on fixya and give more details on your pc and the harddisk..
Apr 17, 2009 | Computers & Internet
Error code 37
Hi there
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
  1. Open Control Panel and select System.
  2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
  3. Scroll down the Device Manager window and identify the faulty hardware from the list.
  4. Right-click on the hardware and select Update Driver.
  5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Good luck
Jan 14, 2009 | Computers & Internet
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
IBM ThinkPad 570E Notebook Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
