Question about Frigidaire GLER642A Electric Dryer
Getting error E68 on display
Woke up the other morning do the dryer beeping with E68 error on display. Now dryer does not seem to be heating.
  • Anonymous Dec 17, 2008
    1. When getting error code E68 and constant beeps, the manual says start button could be jammed. ANy solutions besides having to pay a repair man to come out?
Called the repairman.
Posted on Dec 05, 2008
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Dryer codes
The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Feb 13, 2015 | Frigidaire Dryers
What does error code E68 mean?
Hello Friend, this is Z. Thank you for your question!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's perform Key Test to determine which button is at fault by entering "Function Test Mode". To perform the "Function Test Mode", doing the following:
Press and hold the START and CANCEL button at the same time for roughly 10 seconds. The stuck key should blink.
Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis.
If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area.
Hope this helps!
Jul 27, 2014 | Frigidaire GLGQ2152ES Gas Dryer
I have a frigidaire affinity that is beeping with code E68 HELP???
Good Morning Friend,
I understand that your Frigidaire Affinity dryers is beeping and displaying an E68 code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
E68 on frigidaire dryer
Good Morning Randy, this is Z. Thank you for your post!
Typically error code E68 on your Frigidaire dryer can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exists, the electronic control will possibly need replacing. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, then you may have a faulty heating element. Best regards!
Apr 01, 2014 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Our dryer is beeping and is displaying an error code of E68. I hit Cancel to try to reset it, and it goes back to numbers (20 minutes or whatever), then after a couple seconds goes back to E68. I hit...
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
Jul 05, 2008 | Frigidaire Dryers
Frigidaire GLER642A Electric Dryer Logo
500 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
