I'd suggest you to connect your external hard drive to a different USB port and try copying and check if that fixes the issue.
Also, boot into safe mode and try copying the same and check if you can
successfully complete the copy operation without any errors.
Refer the below link for more details on how to start computer in safe mode:
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
If you're able to successfully copy the file in safe mode, it indicates
that one of the third party application or start up item is causing the
error.
You could put your system in clean boot state and check if any third
party application or any services is causing the issue and hence the
error.
Putting your system in clean boot state helps in identifying if any
third party applications or startup items are causing the issue. If yes,
you may go ahead and disable or uninstall the same.
Follow the below steps to put your computer in clean boot state:
1. Log on to the computer by using an account that has administrator rights.
2. Click Start, type msconfig.exe in the Start Search
box, and then press ENTER to start the System Configuration Utility. If
you are prompted for an administrator password or for confirmation, type
your password, or click Continue.
3. On the General tab, click Selective Startup, and then click to clear
the Load startup items check box. (The Use Original Boot.ini check box
is unavailable.)
4. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
5. Click OK, and then click Restart.
Once the system is in clean boot state, try to copy the files and check if you're able to copy files without any errors.
Refer the link below for more details:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
After you have finished troubleshooting, follow these steps to reset the computer to start as usual:
1. Click Start, type msconfig.exe in the Start Search box, and then
press ENTER. If you are prompted for an administrator password or for
confirmation, type your password, or click Continue.
2. On the General tab, click the Normal Startup option, and then click OK.
3. When you are prompted to restart the computer, click Restart.
1) Download (0x8007045d) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Try that, it sounds like a registry error. If it doesn't help let me know.
