Magnavox fp5210 sound but no pic
Tv has slight sound but only a black screen
3 Suggested Answers
salt56
  • 373 Answers
SOURCE: FP5210 W103 52in Projection TV
You are likely to have a bad flyback transformer...it is the square like device that has the big red wire coming out maybe 3 wires all big and red....Look on this device for any burned places (inspect with light) or holes Could be high failure part...the part number is 483514067128....this part number is popular in various other chassis....Hope this helps...Dennis
Posted on Jun 16, 2008
  • 608 Answers
SOURCE: Magnavox FP5210 W104 was watching fell asleep woke
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps kits can be bought online ,are inexpensive and, if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 14, 2010
Where is the reset switch on 52 inch magnavox model #fp5210 w104
This model does not have a reset switch of any kind.
What is set doing or not doing?
Steve
Oct 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
Magnavox projection TV - Sound cuts off when changing channels.
Yea. Your model FP5210 is much older than one with digital SSB board. Still would think that the mute is being activated; probably by the ucontroller/cpu IC.
Apr 14, 2010 | Televison & Video
Screen went to a 4 inch pic in the center of screen, then total black. All other functions work, just no pic
if the picture shrink into the center of the screen about 4inch then goes blank. you do have problem with your vertical drive IC, it's either loose contact with the board or the vertical IC already malfunction.
Jan 14, 2009 | Philips Magnavox 27MS343S 27" TV
Pic.not fitting on screen
the black bars on the sides are normal there are settings in the menu to change the screen sizes.
Dec 01, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Tv repair
You don't have to buy a new tv, it is a fairly simple problem, your vertical ic is blown, and it could be the powersupply to the vertical ic also. To verify, slightly increase the screen voltage, and a horizontal line will appear on the screen, if the voltages is okay, change the ic, but first try resoldering the ic pins. Good luck
Jan 14, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
No pic or sound
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 22, 2007 | Philips Magnavox 42MF521D/37 Television
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
How to clean the screen
Philips has Projection tv, screen cleaning fluid and a soft brush also to clean your set. You can buy this in most stores like Walmart or online. And remember that your screen have grooves in it so follow the patterns. I think most goes up and down. Hope this helps!
Sep 11, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
