Question about Gadget Universe TC 309 Digital Camera
CD doesn't work Strong Idea TC-309 Spy camera pen
I have my doubts on how i have placed the batteries.
Connection always fails.
Battery draining overnight
First, make double sure that there is nothing left on that would drain your battery. Secondly, if you have ANY doubts about the integrity of your battery (even if it tests out O.K. at your local parts store), replace it.. Myself, if my vehicle ever fails to start correctly , I get a new battery. In the long run, poor batteries are the most expensive batteries you can have. Batteries can also have an intermittent internal problem that cannot always be detected by testing. My opinion, in a nut shell is that you need to replace your battery.
Oct 28, 2013 | Ford Focus Cars & Trucks
It takes several attempts for the remote to work,could that be a weak battery
possible solutions:
weak batteries
batteries not seated correctly or too loose against contacts
battery contacts have corrosion on them (use a pencil eraser to clean terminals)
rare: button solder connection failing.
Always check/replace the batteries prior to further troubleshooting.
Apr 12, 2011 | Toyota Highlander Cars & Trucks
1993 XJ6, has a battery drain I cant find. Sat for 1 week, and the battery was fully drained. Now I have no computer, gauges, headlights or ignition with fully charged battery. Dash lights, windows, radio,...
You've got a short in a wire which causes the battery to be drained. Check all wires going to headlights. May have a cracked or exposed wire. May also be the headlight switch.
Dec 16, 2017 | 1993 Jaguar XJ6
I am using my nokia 5130 xpress music in internet connection either with my data cable or through a bluetooth device.Will the action hamper my phone? plz clear my doubts.
NO. It is meant to be used. You are not doing anything that it is not meant to do. But, remember that if you use the BT connection then the phone may get hot and use up more battery. In the long run it may be harmful as the battery will wearout that much faster and the heat has always caused damage everywhere. So use the cable connection as long as you can. Bt is fine but the phone had to work double, by working the BT to work the GPRS. In case of cable it just has to concentrate on the GPRS.
Nov 27, 2009 | Nokia 5130 Cellular Phone
01 heritage. Engine light comes on, odometer goes blank, speedo freezes or goes to zero, bike still runs. Loose connection? Short?
yes thats a good place to start-always check wiring 1st-sometimes things that appear normal can be corroded but i think your alternator battery or regulator is failing-test it dew u have a manual!!
Aug 05, 2009 | 2001 Harley Davidson FLSTC - FLSTCI...
Cannot connect ps3 to Gigaset SE587 router
Before you test you connection see what the percentage of the connection is, if it's less then %50 it won't work with wireless unless you move it into a place with a better connection
Jul 15, 2009 | Sony Computers & Internet
Razr V3 - Outbound Calls fail
sounds like a signal problem check the bars of signal on your phn might be the antena try placeing your sim into one of the other razers and see if call goes through and let your service provider know they can send all info to phn like a new activation might be a issue where you cant connect to a tower if thats the case youll need to talk to your service providers tech department and have them check for the lrn easy way to see call your phn and see if you get dead air or fast busy signal
Feb 21, 2008 | Motorola Mobility RAZR V3
Wont Power up
DC Jacks are commonly failed on all laptops period. Its a port where the Consumer is applying pressure to the board and a cord is constanltly getting pulled. Dells are a pain at times because the jacks are sensitive and the layout is not in My opinion a good design. IE: Inductors, Caps, Data issues..And Other components cracking from normal use. These are also not a cheap jack by industry standards and weve repaired a ton of them..
Try an adapter first but I am doubtful it will solve as you stated the connection was bad prior..
If you need more help yell..
Feb 12, 2008 | Dell Inspiron 710m Notebook
My zoom is nott coming out
Very doubtful that disconnecting it is related to the problem. Make sure batteries are perfect. If that doesn't help try the light banging tip. It is always worth trying. It is not uncommon for connections to wear, loosen or decay over time. There are many contacts and connections in a camera. Banging it from different positions against your palm may help it make connection or make a better connection and correct the "electrical connection" problem. I always try "using the hammer" before scrapping something or sending it off for repair.
Nov 22, 2007 | Casio QV-R51 Digital Camera
Gadget Universe TC 309 Digital Camera Logo
304 people viewed this question
Top Gadget Universe Cameras Experts
Are you a Gadget Universe Camera Expert? Answer questions, earn points and help others
