Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer is saying cannot use set paper in asf
Printer is saying align print head then I press ok printer is saying cannot use set paper in asf
Garfunkel01
  • 56 Answers
SOURCE: Pixma MP780 Printer, not printing
sometimes those measures of ink levels are not very accurate. actually they're usually rather far off... try a new cartridge Usually the easiest solution.
Posted on Aug 17, 2007
SOURCE: Does not print on paper
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Daniel
Sydney
Posted on Nov 04, 2007
  • 181 Answers
SOURCE: canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Posted on Nov 17, 2008
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
SOURCE: Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Posted on Jan 26, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
How do I align the head on my Model-PIXMA MP 970 Canon Printer?
In short, while the printer is On, press the Home button on the printer, use the up-down button to scroll down the menu and locate "Settings", again scroll down and locate "Maintenance", press "Ok" and locate "Auto Head Align" and press "Ok", again press "yes" when you see a confirmation message on the screen. The alignment page will print out. Make sure there's paper in the tray (not in the adf) before performing this.
The long procedure is given below (if in case you need it):
Press and release the On/Off to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  1. Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  2. Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  3. Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 10, 2011 | Canon Office Equipment & Supplies
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
What is E7 on the canon mp160, and not working anyway..
When the head alignment sheet was not filled in properly Printer show E7.
  • Confirm circles on head alignment sheet are filled in properly MP160
Head Alignment Sheet The head alignment sheet was not filled in properly.Confirm the circles were filled in as follows:
Good example:
Bad examples:
If more than one circle is filled in, reprint the Head Alignment Sheet.
Print Head Alignment
  1. Ensure that the printer is powered on and open the paper output tray. (Confirm that the paper thickness lever is set to the left.)
  2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder (or ASF).
  3. Press the <Maintenance> button several times until [P] is displayed in the LED.
  4. Press the <Black> or <Color> button. The machine prints the head alignment sheet.
  5. From each group, select the pattern which has the least visible streak.
    Example of the pattern with the least visible vertical streak
    Example of the pattern with the most visible vertical streak
  6. Pencil in the circles on the left side of the selected pattern, using a dark pencil.
    < 1 > Good example
    < 2 > Bad example: Checkmark
    < 3 > Bad example: Line only
    < 4 > Bad example: Not dark enough
  7. Open the document cover and load the head alignment sheet on the platen glass.
    Note: - Place the printed side down.- Align the sheet with the alignment mark (shown by the arrow) on the lower right corner of the platen glass.
    05sj00115_06.gif Alignment Mark
  8. Close the document cover gently.
  9. Confirm that U is displayed in the LED.
    If U is not displayed, press the <Maintenance> button several times until [U] is displayed in the LED.
  10. Press the Black or Color button.
  11. The machine scans the head alignment sheet and aligns the print head automatically.
Feb 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Not printing black
To align the printer from the control panel
1. Load letter, A4, or legal unused plain white paper into the input tray.
2. Press Setup.
The Setup menu appears.
3. Press to highlight Tools, and press OK.
The Tools menu appears.
4. Press to highlight Align Printer, and press OK.
5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
Recycle or discard the page.
A success or failure message appears.
Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
cartridge.
6. Press OK to continue.
7. Recycle or discard the page.
Oct 13, 2009 | HP Photosmart C7280 Laser Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My Canon MP 150 continues to return the e19 error message after trying to scan the alignment page. How do I fix that?
Hi ...
Well it looks like the head alignment sheet was not filled in properly ...
Confirm the circles were filled in as follows: Good example:
Bad examples:
    < 1 > Good example
Please vote if this helps .... Cheers :)
Jul 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
272 people viewed this question
old marine
old marine
