Question about JVC Cybercam GR-DVP7 Mini DV Digital Camcorder
Can't transfer video to PC
I tried everything but my laptop just doesn't seem to detect the connection when I connect it via USB cable.
  • 3 Answers
SOURCE: jvc GR-D290
Hi, Since videos are taped in DV format, you need a firewire card (IEEE-1394) and cable. These are cheap. May be your PC already has a firewire card. Just check. Windows XP recognises automatically the camcorder. Moreover, its integrated video capture/editing module, Windows Movie Maker, is very userfriendly. USB connection is only good for downloading still images (photos) to your PC. For more information, go to good luck
Posted on Mar 17, 2007
SOURCE: gr-d290
it is possible to transfer video via usb however it requires a video capture program windows movie maker works apparently and the cyberlink software that comes with the camera will do it too. To do it stick the usb cable in and turn the slider switch to play with the lcd screen open. Then go into your video capture software and navigate thru to capture from video device. If you cannot capture with sound then you need the appropriate audio driver. The cyberlink program works best for video capture via usb as it already has the audio codecs.
Posted on Aug 15, 2007
  • 3 Answers
SOURCE: Cannot transfer video to Laptop computer through USB
I bought my JVC GR-270 (same as GR-290, but no remote) in 2004. On page 45, top right hand column of either manual (the original and the on-line one on this site) the claim is made that "Using USB cable it is possible to do the following things: Transfer still/MOVING images recorded on a tape to a PC." After many unsuccessful attempts at trying to use the USB cable for transferring moving images to my PC, I called JVC technical dept. They told me that the MANUAL WAS WRONG....and that in order to transfer MOVING images, I needed to purchase a FIREWIRE cable. Indeed, that is the solution. However, If your PC has no FIREWIRE input jack you must also purchase a FIREWIRE adapter card. Don't skimp on these items, get a well shielded cable and a name brand adapter.
What burns me is that I looked at the manual in the store and only purchased the camera because it claimed that the enclosed USB cable would work for moving images. JVC denies responsibility, even though their manual is clearly wrong, and they know it.
Posted on Apr 14, 2008
SOURCE: JVC ieee 1394 not connect
This is not a solution to a problem.We need solutions not suggestion about a system we are not being able to use.
Posted on Apr 19, 2008
SOURCE: jvc digicam gr-d370as
Posted on Aug 10, 2008
  • 763 Answers
SOURCE: jvc gr-d870
install the cd driver camed with your camcorder to your pc. after the installation it should be recognizable. hope that helps!
Posted on Sep 11, 2008
0 characters
1 Points
I am unable to connect my handycam with my pc via usb please send me proper sugeestions
The USB cable connection ability in Windows for video transfer was discontinued after Windows XP. Anyway, the quality of the video through the USB cable is terrible.
You'll have to buy and use a DV to Firewire cable to retrieve the video off of the camera. If you don't have a Firewire 800 adapter on your computer, you'll have to buy an adapter add-on for your desktop computer. If your laptop doesn't have a Firewire port, then you're out of luck -- buy a new laptop with one.
See pages 43 on in the user manual for more information.
Dec 22, 2010 | Sony DCR-HC54E Mini DV Camcorder
Sony DCR-TRV8 video transfer problems
The USB drive for Sony CAM you can download from Sony web but the USB will not allow you to transfer video from your CAM only for memory stick
However if you have firewire input on your Laptop, have you? normaly if you have firewire input on your laptop as soon as you connect your CAM it will detect automatic either with windown movies maker or with Nero
Sometime the firewire from CAM defect I repaired a few of them with this problem
Can you conect this CAM to another computer or try different cable ?
Or tell me exactly what input you have on your laptop such firewire input, PCMCIA slot
Dec 04, 2008 | Sony Handycam DCR-TRV8 Mini DV Digital...
Camcorder as source for video software not found
if you have a nv-gs35 i am pretty sure that ths camera can not do video transfer via usb, the port is not usb2. it can transfer video via the dv port only. please check the operating instructions.
Mar 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
I could not find the manual for this model on the web, so I'm giving you my best guess.
I found some information that said you could transfer still images and Motion-JPEG video clips to your computer using the USB port.
In general you cannot transfer video to your computer using a USB. To transfer video from most camcorders you need a DV (Firewire, also called 1394) cable. You also need some software.
I'm thinking that when you have an SD card in your camcorder there's some way to tell it you wish to record Motion-JPEG clips to the card rather than full video to the tape. If you've created a standard recording I don't think you'll be able to transfer it with USB.
I believe Windows Movie Maker will let you connect to your camera using a DV cable. I used software called Scenalyzer. A full demo is available free of charge at The demo will leave a "watermark" on your video. If you like the software you'll need to buy it in order to capture video without the watermark.
If you have any more questions, let me know.
Dec 28, 2007 | Canon MVX330i Mini DV Digital Camcorder
Panasonic Palmcorder PV-GS85 Problem: Capture video with Windows Moview maker via USB
I believe you have to use a Firewire (IEEE 1394) cable to transfer the video. From what I have read, the USB connection is only if you want to use the camcorder as a "live" camera.
Dec 09, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
How to transfer video from camcorder to PC
The camera has two interfaces, the firewire or ieee-1394 for transferring video to the computer and serial interface (RS232) to transfer picture from the memory card to the computer. If you do not want to use either interfaces, you can buy cheap memory card reader (less than $10) to transfer the image from the MMC card to the PC via USB. If you want to transfer the video to PC and does not want to use the fire wile link, then you have to buy a video capture device (cheapest is less than $30)and connect to the video-audio output. I would recommend to use the firewire if you are intending to transfer the video.
May 23, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Transfer video from cam to pc via 1349 cable
my computer recognises handycam when i connect via usb. but iam not able to connect via ieee1374 im ycom,devicemanager, there is no imaging device when i connect via iee1374 i need some drivers or in need to make some changes in cam comp is
amd athlon 64 bit, 700mb ram, dvd ram drive,my 1374 port is with via chipset.
Apr 01, 2007 | Sony DCR-HC32E DV Digital Camcorder
Camera detection by windows xp
Hi, You need to connect the cam and PC using 4 pin to 4 pin firewire cable.  After connecting,
Switch on the cam.  Open Windows Movie Maker and import the video from device.
Aug 25, 2006 | JVC GR-D370 High-Band Digital Video Camera...
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
JVC Cybercam GR-DVP7 Mini DV Digital Camcorder Logo
26 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
