Question about Hotpoint Washing Machines
Aquaries the word test appears on display
The word test appers on digital read out machine works but not correctly
  • robert_turne Dec 05, 2008
    the answer to my question was 100% correct well done guys
  • 734 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Posted on Dec 05, 2008
  • 10,515 Answers
Hotpoint washing machine shows test in display Symptoms: Hotpoint washing machine just keeps running on its own and won't accept a program This is caused when the demo mode is accidentally switched on. Instead of using a combination of two keys that need two hands to press, Some Hotpoint washing machines use two buttons next to each other to put the washing machine into demo mode. Even a leg leaning against the start and cancel buttons while reaching over the washing machine can turn on the demo (test) mode. To turn it off and get the washing machine working again, switch the washing machine on, then press and hold the centre line between the start and cancel buttons so that you are pressing them both in simultaneously. After a few moments you should see "d_OFF"
Sometimes this works first time. Sometimes it needs repeated attempts. If you are having trouble, try waiting until it's finished the spin section of the demo and catch it before it starts again
  • Hotpoint Master
  • 19,396 Answers
Try first unplugging the appliance AC cord for ten minutes, and see if this clears the error message,
  • Ginko
    Ginko Dec 05, 2008
    If unplugging the power cord does not clear it, do the following.
    Hold down Start/Cancel button until you see all the leds on control panel turning on. That means that the appliance is in diagnostic mode.
    Hold down both the Start/Cancel and On/Off buttons at the same time, until you get the word OFF on the display.
    The display should get back to normal , and the machine operative again.
    If that does not work, try procedure again, if still no luck, that means that there is a faulty part. In that case call a technician.
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
Hi. I have a Casio CE-3700 that is only used for a few weeks of the year. Once I month I try to turn on the machine and leave it powered up for around a day. I am now wanting to actually use the machine....
It sounds like the machine has lost some programming. What you were doing once per month is what I recommend if not used regularly, but the battery has probably now got to the stage where it is too old to even hold charge for a month. It is probably best to get the battery (internal vanadium type) replaced as it may have started leaking if it is too old. The dealer who replaces it can reset your decimal places at the same time. If you just want to get it running as is and take a chance, then do the flag clear (to get the FFFFFFFFFF on display then SUBTOTAL) on one of your WORKING machines, and tell me the big number that it prints out (this will not lose any data on your working machines, it just reads the settings)
Jul 26, 2010 | Casio Parts Cash Register PC Desktop
How do I change the time stamp heading- when I send a fax it shows the wrong month , year, date and time
1. Press <function> then the "Down Arrow" below the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" below the <start> button until [DATE&TIME SET] appears.
3. Press "Right Arrow" (current set date will appear).
4. Enter two digit number for day. (To correct a mistake press "Left Arrow")
5. Enter a two digit number for the month.
6. Enter the four digit year.
7. Enter the two digit number for the hour, then two digit number for the minute.
8. Press <start/memory> (The display will read [POLL SECURITY])
9. Press <stop> to exit.
Mar 11, 2010 | Sharp UX-B750 Inkjet Fax
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Want to play dvd's from any region. My JVC XV-S332SL/XV-S402SL DVD Player is restricted to Region 4
hi you can try this it been tested and will work if done correct we just tested this and had no problems unlocking this in the shop lol.
1. Power the player off.
2. Press and hold 'DVD Menu' and 'On Screen' on the player.
3. Power the player back on.
4. Release both buttons.
5. Press Standby. The display should now read either TEST 2, TEST 4, or TEST 6
depending on the machine's current region setting.
6. Press DVD Menu twice on the player.
7. When the display reads 000 5858 use the up and down buttons to change the
000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until
they read 0000 for Region Free, 0001 for Region 1, 0002 for Region 2 or 0004 for
Region 4....
NB: DO NOT Use Region 20!!!
9. Press Enter on the player.
10. Press Standby.
11. Wait 5 Second.
12. Press Standby again.
Some titles may not play in region free setting. If this happens select the
needed region.
JVC XV-S332SL, , XV-S402SL,
riz.
Aug 17, 2008 | Televison & Video
Unlock ford car radio. have code.
can you give the number or name of the model
Apr 05, 2008 | Car Audio & Video
PHASER 8550DP
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Mar 08, 2008 | Xerox Phaser 8550DP Printer
Display lights
make sure there water going to machine, remove fill hose to see check inlet filters.good luck eire
Dec 07, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
