Guide Plus on RCA television
We are unable to receive updates for the Guide Plus on our RCA model t.v. When we hit the Guide button (on remote) we get the following message. We are sorry that your television is not able to receive data to update your guide plus television listings. Likely reason is your cable company has blocked the information contained in the television signal. Please contact cable company and ask them not to interfere with the free data contained in over the air broadcast signal which supports your Guide Plus feature. I have contacted the cable company, and they advise they are not blocking any information. They advise to contact RCA for the solution.
  • 2 more comments
  • nixonc Dec 28, 2008
    I get the same message - comcast says we need a converter box. I don't believe them!
  • Anonymous Mar 04, 2009
    I have the same problem. Brighthouse says its RCA's fault but I can't seem to reach them.
  • steinman5 May 02, 2009
    I also have a 61" RCA TV which I did get my Guide plus when I first went with Comcast until about 30 days ago. Now I get the same message and Comcast says they are not blocking it. It work before, so something has changed with Comcast. Everyone who has Comcast needs to complain to them. I never had a problem with Charter or Avenue when I lived in IL. Also when I moved in Feb 09 and got Comcast the guide would not work. After I complained to comcast it started working again for about 30 days then it stopped.
    If it is an RCA problem, since when did RCA go into the cable business.
    Bob
  • Anonymous May 20, 2009
    The Guide plus stopped working on both of my RCA TV's. I have Comcast as my cable provider.
  • 42 Answers
My guide quit working also on my RCA 61" big screen and I called the cable company and he said something about the encryption data had changed and I needed to call RCA to find out what to do and the whole time trying to sell me a converter box. It is the cable company's fault or the guide wouldn't have put that message up to start with. We all need to call the FCC!!!
Posted on Dec 30, 2008
  • Dale Ellenberg
    Dale Ellenberg Oct 15, 2009
    Hey Bob, RCA is not actually in the cable business. RCA doesn't make anything anymore. Thomson Multimedia Inc owns RCA now and have for a long time. The cable company receives the analog signal from Tv Guide which operates your guide plus. If the encryption is not right which they changed and probably changed again since has to do if your cable company wants to mess with it. It is up to the cable company to furnish the signal to your set that comes from tv guide. I am thinking that is was analog so everyone would be SOL for the guide anymore. If it went to a digital signal now since the digital tv act then either Tv guide is sending the wrong encryption signal and you need to talk to the cable company to see if they are still sending the TV Guide signal and if so then you would need to call RCA or Thomson Multimedia Inc or whatever brand your tv is and they will help you to put new codes into your tv to receive the new encryption so you will be able to get your guide. So Bob RCA and several other brands of tv's are in the cable business per se.
Mitsubishi big screen model vs-50604. i hit a button on the front of the tv and now all i have on the screen is a caption that says installng guide plus data now. is there a reset on the tv anywhere. i...
Open the front panel. Just to the left of the RCA imputs is a small button that says reset. You may need to use a pen or paper clip to press it. Press that and the system will reset .That should fix your issue, or do like me and get a Sharp. LOL. My bulb went out 2 times and I got irritated with it.
Nov 07, 2013 | Mitsubishi VS-50605 50" Rear Projection...
1997 RCA TV GUIDE PLUS MODEL NO. F36674ET.UNIVERSAL REMOTE NO INPUT BUTTON. HOW DO I GET TO VIDEO CHANNELS.
A lot of the older RCA sets if no input button had the inputs on a channel between 90 and 99. This set may also have a way to enter once you go into the customer menu.
Sep 01, 2012 | Televison & Video
I have a RCA guide plus gemstar t.v.I have lost the remote.to set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
Sep 17, 2011 | RCA 36F530T 36" TV
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
May 09, 2008 | RCA F32648 32" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
RCA UNIVERSAL GUIDE PLUS GEMSTAR
http://support.rcaaccessories.com/index.html
http://www.remotecentral.com/features/r-rca.htm
Try using the information from these two websites. It may help.
Oct 03, 2007 | Televison & Video
Televison & Video Logo
458 people viewed this question
Top Televison & Video Experts
