Question about Palm TX Handheld
Keep getting error code for the system and noticed that the touchscreen doesn't recognize stylus or even a finger touch.
  • JDTec
    JDTec May 11, 2010
    Do a hard reset, do you know how?
    Problem Solver:
  • 14 Answers
Yes, I will give you the steps to perform a Hard reset. Just follow the below link to perform a Hard reset on the device.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=286,E=0000000000194507740,K=9510,Sxi=14,Case=obj(42094)
Posted on Dec 25, 2008
Irulu recognizes finger but not stylus
Have you tried a stylus for capacitive screens?
Apr 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
Nuvi 50 LM touchscreen claibration
Hold your finger in the center of the screen. power on. Keep finger on screen and after 45 sec see a black dot on a white screen displaying touch me.
Jul 26, 2012 | Garmin Nuvi 50 LM
My HP tm2 digitzer pen suddenly stopped working but everything else is fine the touch screen still responds to my finger just not the pen. what could be causing this and how do I fix it?
First thing to try is re-callibrating your stylus. See if your system recognizes it. If not the next thing to try is installing this HP Stylus Driver SP48676 found in this posting
tm 2050er pen problem
It was difficult finding this driver pack. If you search under your model you will only get the original driver, you may need to cut and paste the following link into your browser window.
ftp://ftp.hp.com/pub/softpaq/sp48501-49000/sp48676.exe
This link contains more helpful information but its links to sp48676.exe don't work.
touchscreen and pen not working on hp touchsmart tm2
If your stylus still doesn't work try the advice in the last comment in the thread by NickGl Student ‎01-28-2015 11:27 PM
I had the same exact problem as you and I finally got it figured out. Go to your task manager then to the services tab and scroll down to the task TabletInputService and you should see that it is stopped and when you right click and hit start you get an error message saying that it pretty much could not find any supported devices. So click the Services button in the bottom left corner of the task manager and find the task Table Pc Input Service and right click it and go to properties. Once you are in properties stay in the General tab and change the Startup type from disabled to Automatic and then apply the setting. You should now be able to start the Tablet Pc Input Service and the touchscreen and pen will work.
Hope this helps out someone being such a late post.
Aug 08, 2011 | HP Digitizer Pen For HP Touchsmart Tm2...
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Touch screen is completely not working ATT 8525.
contact the manufacturer or your cell phone provider about this error. They might of created a firm ware upgrade to provide a solution to this error.
Let us know if it continues or they do not have anything on file.
Thanks for your time!
Sep 08, 2008 | Cingular Wireless Cingular 8525 Smartphone
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Cracked touchscreen
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that. And we could provide all kinds of PDA accessories. Here are some information for you In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen. Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different from LCD screen, the touch screen is an optional component for PDA, SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
Sep 09, 2007 | T-Mobile MDA
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
