Question about Roper RAS6233KQ Top Load Washer
Roper RAB5232WO Washer No Drive
The washer fills and pumps out but does not spin or adgetate. The is a black power on the floor under the washer that seems to have come from between the motor and the drive or transmission unit. Is there a particular part that breaks that creats a black power under the washer?
  • 530 Answers
That would be your drive coupler. the part number is 285753a this will fix this. if you need help figuring out how to access it just let me know.
I hope this helps you
Posted on Jan 05, 2009
Roper washer
That could be your lid switch. You should hear an audible click when you shut the lid. If the washer act like it is trying but won't spin that could be the drive coupler. I have a page which includes a service manual HERE
Sep 24, 2012 | Roper RAX4232KQ Top Load Washer
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 20, 2010 | Roper RAX4232KQ Top Load Washer
The washer fills up and washes but won't empty or spin.
look under the washer and see if the belt for drum is boken
Oct 09, 2009 | Roper RAS6233KQ Top Load Washer
Washer wobbles
Its the clutch and its causing the drum to spin unbalanced It will need replaceing and a new sealed bearing too
Please rate our help to keep the free service online ++++
Aug 30, 2009 | Kenmore 24032\24036 Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool TAWB600EQ1 - Washer
ck lid switch usually on right side of lid opening or on later models under back corner at lid hinge area
Aug 10, 2008 | Roper RAS8244KQ Top Load Washer
Washing machine
it sounds like the drive coupler is broken you have to look under the washer and see if there is a black powder on the floor if so you will have to take the wrapper off the washer and replace the coupler
Dec 10, 2007 | Kenmore 22422 Top Load Washer
Roper washing machine
It's direct drive. It may have a bad coupler. Did you see any black particles under washer? Also look for oil on floor and bottom of washer. Transmission can leak oil into clutch causing slow spin.
Nov 11, 2007 | Washing Machines
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
32 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
