Question about HP Office Equipment & Supplies
I would like to network our HP color laserjet printer through our Telus wireless router. I connected the printer with a network cable, to the router, but when I tried to install the printer through my laptop's wireless connection it was unable to locate the printer. I printed the laserjet's configuration page but the IP address shows: 0.0.0.0. I do not know where to proceed from here.
  • darleneldg Dec 05, 2008
    Thank you for the quick reply. I am sorry I forgot to advise that the model is HP4650dn. I have been unable to find the HP MIO Menu. Is it in a different location on the 4650dn?
    The Configuration Status says I/P Card Not Ready. What can I do Now??
    Scholar:
  • 68 Answers
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Posted on Dec 04, 2008
  • James Swafford Dec 05, 2008
    Did you go in and configure the card to match your network?
    At this point I would recommend doing a Master Reset. It is also available on the previous support link I gave you. After you do this, follow the instructions on that link word for word to set up the printer again.
    Restoring an HP Jetdirect to factory defaults
    In some cases, it may be necessary to reset an HP Jetdirect print server to factory defaults, either to clear an old TCP/IP address or to verify that any error messages that appear on the TCP/IP status section of the configuration page have not been resolved. The printer can be reset to factory defaults (or cold-reset) by the following steps:
    1. Turn the printer on.
    2. Watch the control panel. When the memory starts counting, press and hold the green check mark button.
    3. Continue holding the green check mark button until the Ready, Data, and Attention lights flash once, and then stay on steady.Release the check mark button when the Ready, Data, and Attention light are on steady.
      The control panel will read, SELECT LANGUAGE .
    4. Press (Down Arrow) button once. The control panel will read, COLD RESET .
    5. Press the check mark button (Select). The printer will perform a cold reset and then continue its power-on sequence.
Hp laserjet wireless not found on my phone
why not RTM? (omg)
read the manual,
all this is covered there. how to CONNECT.
there is no phone support, apple or android. only xp to w10.
on newer printer, far newer, the phone can be linked to HP smart print servers and to your home system printers.
https://support.hp.com/us-en/product/hp-laserjet-pro-cp1025-color-printer-series/4052955/model/4052971/manuals
here is HP site page showing how to do that,
http://www8.hp.com/us/en/ads/mobility/overview.html
first pick a printer that does that.
using the smart app
or ePrint.
there are many ways to set that up, but direct cell to printer.
no. (yes new products can do direct cell print)
that is called wireless direct print , features, as see here.
http://www8.hp.com/us/en/ads/mobility/wireless-direct-printing.html
you said you have phone (cell apple or android?_)
then said have a laptop.
my cell , is android and I use local wifi , to save 3g charges
do you?
my laptop has internet connections 2 ways, wired, and wireless
does yours have wireless. seems not.? but.... do you?
you said no router, but if you go to any ISP today
and he installs internet service, there are 2 hidden router now
inside the old name modem,
the modern cheaper modem has that, hidden is side.
has 3 things in the black box.
so what do you have there that we cant see, devices to the ISP
with names and model numbers.
knowing that tells the helper what is possible , (all things)
my guess is you want to print, using the CELL.
if you dont have eprint mail the docs or photos to the laptop
then, print from Laptop
to printer using a USB cable, (USB is 10x more easy to make work)
your printer can connect up 3 ways.
Printer USB to PC. direct wired printing. ( always a choice, direct)
Ethernet to router. wired. (all things connected to this router can print.
wireless to router. printer to router joined, and print from any thing at home connected to said router.
if it must be wireless, (you must have that?)
then buy a router. and use that, and is safer behind any router firewall vastly saver too boot.
Jun 25, 2016 | HP Laserjet Pro Cp1025nw Color Printer
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
I have followed directions for putting my HP LaserJet 4050 series PCL6 laser printer online via our home router. I have downloaded the correct driver. The printer shows in my list of printers, but w
1. Setup the printer with the router via network cable (This model is not wireless) on DHCP. The router should see the printer as a IP address on the web admin.
2. Next re-install or configure the printer via a network connection and IP.
Feb 11, 2013 | HP LaserJet 4050 Series PCL 6
Hp laserjet 3050 - old printer can it be wireless
Hi
Connect the Printer to the Computer which is connected to Wireless Router
Share the Computers and share the Printer (Add Printer - Add network printer - select printer from network)
You will be able to print from anywhere
Regards
Oct 03, 2012 | HP LaserJet 3050 Printer
D-Link DIR-615 Wireless Router not connecting with HP Network Printer
Please use the utility disc that comes with your printer. It will help you to connect your printer to your wifi router.
Or please check if you type the correct SSID of your wifi (Wifi Name). SSID are case sensitive.
Nov 04, 2011 | D-Link DIR-615 Wireless Router
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
How do i set up my hp 1012 printer to print wirelessly?
1.Position the printer near your wireless network's router. Plug an Ethernet cable into the Ethernet port on the back end of the printer. Run the other end to any of the numbered ports on the back side of the router. Press the "Print Report Page" button on the printer.
2.Navigate to the setup page listed on the report page and click the tab labeled "Networking."
3.Scroll to the "Connections" heading and click "Wireless." Navigate to the tab labeled "Wireless Setup." Click the "Start Wizard" button.
4. Follow the prompts to connect the HP 1012 to your wireless network. Click "Finish" and close the browser.
5.Open the "Start" menu and navigate to "Network." Choose the "Add a Printer" option. Click "Add a network printer."
6. Click "HP Laserjet 1012" and choose "Next" and "Finish" to access the printer through your computer's wireless connection. Repeat the process of adding the printer on any other computers on the wireless network.
Please follow these steps and let me know if it works or not
Nov 01, 2010 | HP LaserJet 1012 Printer
Hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Feb 23, 2010 | HP Color LaserJet 2600n Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
714 people viewed this question
Ben Johnson
