Computers & Internet Logo
Anonymous Posted on Jun 25, 2012
Bt internet issue
On my xbox 360 my xbox 360 internet keeps on laging when i am on 50 MB speeds how do i fix it
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 55 Answers
  • Posted on Jul 02, 2012
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
55
Questions
0
Helped
9021
Points
119
Do a speedtest. Go to http://www.speedtest.net/ and see if you are really getting what you paid for.
Homefront for Xbox 360 Live keeps dropping internet connection, How can I fix this?
I know this was a common problem for players a month or so ago but THQ released a patch that seemed to resolve the issue. Did you download the patch for the game? If you go into your network settings on your Xbox, does the NAT report as being open?
tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
How do we set up the x box 360 to go live?
You will first need a high speed internet connection, if you already have one just simply connect a network cable to the xbox 360 and go to "join xbox live" on the xbox 360 dashboard. The subscription is 7.99 a month or 50 dollars a year. Hope this was the information you were looking for.
I can play the game on single player but when i go onto multiplayer is keeps saying disconected returning to single player
1.some one else is useing the network
2.someone is stealing your internet
3.the internet your stealing they found out
4.go online and test your connection speed
make sure your at least .25 mb for upload
2helpful
Can't connect on multiplayer on gears of war 2
AAAAHHHH! DON'T WEIRY, ITS CONNECTIVITY. WHEN YOU GET TO THE SEARCH PART YOU PROBABLY DROP OFF THE REQUIRMENTS. HAVING JUST ENOUGH TO GET ON XBOXLIVE IS NOT GOING TO BE ENOUGH FOR MM MATCH MAKING. GOTO SPEEDTEST.NET TO CHECK YOUR INTERNET SPEED. CLICK ON THE GOLD STAR, HERES WHAT YOU NEED TO PLAT MM ON XBOXLIVE. LESS THAN 60 PING 500MB DOWNLOAD 546KB UPLOAD. WITHOUT IT YOU DON'T KNOW WHAT GLITCHES AND PROBLEMS WILL ACURE. ALWAY RESET ALL MODEMS AND ROUTERS EVERYDAY. HACKING IS NOT LIMITED TO THINGS HOOKED UP TO THE INTERNET.
Lost connection
gears of war two now has an update where there is bot players in the game when someone leaves and also it doesnt require as much speed from your internet. Also before the person with the "best connection" was never host it was just a random person, due to the fact that you have an okay connection you are always going to lagg out. My solution would be this being gears requires alot more then other games run an ip speed test on your computer , if it is under the average speed then its your internet. If it is normal speed then you are just one of the unlucky people that will have to deal with it.
My xbox 360 console does not save my ip address
Are you using a router? Or are you hooked up directly to high speed internet? If you don't have a router, you might look into buying one, they run about $50. If you have a router, in the settings on your Xbox choose DHCP under your network settings. This way your router will automatically give an ip address.
Hope this helps,
81
Speed
no not really, but 54mps is a wireless speed not the actual internet connection speed... if your lagging try wire the xbox and see if that fix's
you could also disable the wep/wpa security for the xbox and hardcode the xbox MAC address into your router
5answers
Xbox 360
Contact the people you get your internet from. tell them you need to register your xbox. I have the DNS issues when i visit my girlfriend at college since they dont like to keep the Download speed high for the students. always fails
Grand Canyon Tech
Grand Canyon Tech
