ATP5 speakers. Power works fine for a while then begins to "flicker". Light on satellite control indicates power is going on and off unpredictably.
  • bob0009 May 11, 2010
    So did this solve your issue? I've still got this issue, and the wires didn't seem to fix it. I'll take it apart to look at it if this fixed your issue.
  • Betty Wood
    Betty Wood May 11, 2010
    Have you looked at the wires on the speakers themselves? Speaker wires are very thin and may have a small cut in the wire.
The sub-woofer for the system sitting on the floor and the speaker wires had been connected for a long time. I disconnected all components and re-assembled them in an uncluttered location, making sure that all of the plugs were solidly pushed in. I have run the system and it has been operating properly for over a day now. This appears to have fixed the problem but only time will tell if this was a permanent fix.
Thanks for the follow up.
Posted on Dec 05, 2008
Altec lansing ada885
All of your speakers get power from your sub. The volume control may have failed or the connection to the sub may be loose or broken. The power light indicates only that primary power is getting to the sub; the amplifier ICs may have failed. It will be necessary to open up the sub (if possible) to find out what failed.
Nov 12, 2012 | Altec Lansing Audio Players & Recorders
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Toshiba satellite m305D screen blanks out after powering up. Power button light is on but the audio controls lights are still off.
do you see anything on screen to begin with?
if nottry removing ram individually.
use an external monitor to see if you have video if you do then you need to tighten the lcd harness as i have noticed on a great many m305's that the lcd and harness become separated, causing the lcd to flicker
if not you need a motherboard
Nov 03, 2009 | Toshiba Satellite M305D Notebook
Toshiba satellite m305D screen blanks out after powering up. Power button light is out but the audio controls lights are still on.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first
Oct 16, 2009 | Toshiba Satellite M305D Notebook
Will not turn on
Page 23...
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
© Disconnect the AC cord, then correct the speaker connections.
May 04, 2009 | Aiwa AV-DV75
After 2 - 10 Minutes Satellite connection is lost
Try this and see if it fixes your problem....first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Dec 19, 2008 | Garmin Nuvi 660 GPS Receiver
HELP ! No/limited volume from satellite speakers
1. Make sure all wall and power outlet switches are on and that all switches for your speaker system are on. Cycle the power switch.(switch is located on the back of the subwoofer) Check power LED on left and right speakers. Is the LED on? If not, power is not getting to your speaker system. Make sure the power cord is plugged into an electrical outlet. 2. Ensure that the speaker input jack is pushed all the way into the appropriate jack. Check all the connections and secure them. 3. Check the connection to the soundcard. Make sure it is connected to the proper jack. This varies from each soundcard manufacturer. (Please refer to your soundcard manual.) 4. Your volume settings are too low or muted. Increase your volume by pressing the + key located on top of the right satellite. You can also check your volume through the volume control located in the taskbar. To mute and unmute the speakers, press the + and - controls at the same time.
the part that is for your problem
This is an indication that the satellite speakers are not plugged in all the way to the subwoofer. You will hear a slight "snap" sound if they are plugged in all the way. The inputs are color coded and shape coded (triangle and square). Make sure they are aligned properly.
Mar 28, 2008 | JBL CREATUREIIWHITE Computer Speakers
ALTEC LANSING ADA745 WILL NOT POWER UP
check whether the adapter is fine or not..
that may also be a problem...
Mar 26, 2008 | Audio Players & Recorders
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
Computers & Internet Logo
David Payne
David Payne
