Question about Brother BRTPT65 PT-65 Label Maker Printer
How do i limit the space between labels
I am wasting too much tape between labels, i cannot find the manual and I have tried everything and can't remember how to change the settings for this.
  • june_morace Dec 04, 2008
    James I think that is what I did because I couldn't find a solution, thanks for jogging my memory.
    Scholar:
  • 68 Answers
I know exactly what you are talking about, the sad part is that I never found a fix for it. The only thing you can do is print more at the same time using a few spaces in between and cut it with scissors. There are some models that will waste over 1" on every label printed. It seems wasteful, but is keeping the machine from jamming and causing more problems.
Posted on Dec 04, 2008
  • James Swafford Dec 04, 2008
    Glad I could be of assistance to you. Have a Great Day!
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
http://www.ptouchdirect.com/ptouch/manual/PT1750.pdf
Have a good day.
Mac =)
Apr 22, 2013 | Brother P-Touch 1750 Label Maker
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
Installing xp
always use NTFS - NTFS is the standard file system of Windows NT, including its later versions Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008
Sep 10, 2009 | Microsoft Windows XP Professional for PC
Refrigerator side is freezing everything and is set on lowest setting. It is a frigidaire brand side by side.
Limit the hile in tha back left bottom corner with a peice of packing tape, leave about 1/4" space instead of the whole opening.
Aug 31, 2009 | Frigidaire Refrigerators
Ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
The font size will not print on #5
I'm not sure if it will work in your case, but I found mine did this too if my text was too long, try a short message and see if it works right then. not sure what the limit on the length is.
Aug 13, 2008 | Brother P-Touch (PT1100SBVP) Label...
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
722 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
