It says reset filter
How do i reset the filter so that the warning goes away
  • 2 more comments
  • Anonymous Jan 30, 2009
    I have the same problem, after clearing the filter, I can not reset the filter timer to 0. Could the Hitachi CP-X28 service centre help to provide solution? Thanks!
  • iambabybob Feb 03, 2009
    I also have the same proble. After looking through user manual, there is no description about such a warning message.
  • Anonymous Apr 24, 2009
    clean the air filter
  • planclan1 May 07, 2009
    I have the same problem with the Hitachi CP S210. It is telling me that I need to reset the filter timer. Are the directions that you gave the same for the projector that I have? I am not able to check it at this time or I would just see for myself. Hope that you can help. Thanks.
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Posted on Jan 14, 2009
Go to Advanced Menu, then Options menu. Go to Filter time and hold the reset button for 3 seconds. This will bring up a sub menu and use the up arrow to reset. Page 37 of the user manual
Posted on Apr 02, 2009
1. Chose "OPTION" on the menu
2. Chse teh "FILTER TIME", then press AND HOLD the right arrow button, or the RESET button on the remote for 3 seconds.
3. Choose the RESET option
Posted on Mar 24, 2009
How to reset the filter timer and lamp! >>
hey to all trying to reset the annoying 'clean filter" or "change lamp" message on the hitachi cps 210 projector.
go onto filter in the menu, then hold down the little reset button on the remote botom left i think,, or right.. it will then go to zero. hold for ablut 5 seconds
that should do it..
dont try pressing reset then execute. it seems to do nothing. gotta use the remote reset button.
hope this helps. i know how annoying the message box is!
Posted on May 31, 2009
Changed water filter, but water filter indicator light does not go on after resetting
See if there is some sort of reset control. Or try unplugging the unit and re plugging it back after a few minute wait.
On most units the lamp goes on to warn of a problem and it is off when all is copacetic.
Mar 22, 2016 | Refrigerators
Message not sent on alcatel pop icon a564c
Your unspecified model of Alvatel cell phone is buggy. Try to do a Factory Reset if bug goes away. You chould look up in your manual if factory reset is available, else you caould visit the office of your Mobile Service Provider, they know how to do a Factry Reset.
A warning, after factory reset you'll lose all your saved data!
Aug 06, 2015 | Alcatel Cell Phones
Tapping/ticking noise when rpm goes above 2000 with check oil warning on my chevrolet lumina ls 2005 model
You will have to take an oil pressure reading and compare to specifications. It could be that the pick up screen is plugged. Do not drive the car as damage to engine will occur.
Jan 14, 2013 | Cars & Trucks
My toyota qualis shows T-Belt warning when i switch on ignition but it does not goes away when i start the engine is it OK
open the od meter timmig belt indicator shift in the side whole the tmmig belt light is reset next miles
May 14, 2012 | 2002 Toyota Tundra
Water filter warning light has come on
Hello. When the water filter warning light comes on it is time to replace the water filter. Once the filter is replaced you will have to reset the warning light. To do that Hold the Lock/Unlock Button and the Water Dispensing Button for (3) Seconds. The Change Filter Light will Blink and Reset. Joe
please rate my answer as very helpful. Thanks.
Apr 21, 2010 | Maytag MSD2756GES Side by Side...
I owns a Toyota Hilux Vigo and recently the fuel system warning light came on, I changed the fuel filter but the light is still on. please advise what could be the problem
You can try to reset the ecu, just switch the ignition into off position, disconnect the sensor cable at the fuel filter housing, turn the key into on position, but dont start your car, connect back the cable, the warning should goes off after fews second.
Apr 03, 2010 | 2009 Toyota Tacoma
Code 2,114,0
Hold stop/reset button until warning goes away.
Feb 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
How do i reset the abs, brake light
If you tap the light with a ball-peen hammer it will go off. Start with a light tap and increase the force with each tap. It will eventually go off.
Sep 20, 2008 | Chevrolet Malibu Cars & Trucks
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Jul 21, 2008 | Sanyo PLV-Z4 Multimedia Projectors
5,634 people viewed this question
jasbo
jasbo
