Question about Akai Televison & Video
On off switch not working
Tv will not go on with remote control. I have changed batteries twice with no result. I can however push the on off switch several times, hearing a clicking sound, not usual, and then hold for about 5 seconds and the tv will come on. by the way I can shut the tv off with the remote control.
Omg you might be able to help me do you know the 3 or 4 digit code associated with the remote i have hunted everywhere
Posted on Dec 05, 2008
My haier le32f2220 has A channel list box that pops up and I can't change channels. All remote buttons do nothing. Changed batteries twice. Anyone have this issue?
·Pull the batteries out from the remote control, and leave it out until step-4
·Press and release each and every button, one at a time on the remote control, until every button has been pressed and released at least once.
If the remote control have slide switches; move the switch to each position, then repeat the button pushing as in step-2. {When you've done, be sure to put the slide switch in the correct position to operate the unit the remote came with.}
·Put the batteries back.
·Try the remote.
http://remotesearch.blogspot.com/
Apr 24, 2015 | Haier Televison & Video
My Hitachi rc1910 remote control keeps heating up excessively to a point where the plastic on the batteries starts to melt
There should be a short circuit inside the remote control. Check it. Contact any service technician.
Feb 12, 2013 | Hitachi CLU-5713TSI Remote Control
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
The remote control has simply stopped working! The batteries have been changed! Nothing on the remote is accepted by the TV. There is no response, not even a flicker from the TV.
Try resetting your remote:
* Remove batteries
* Press each button on your remote, twice. (one button at a time). This should discharge any current left in the capacitors.
* Insert fresh batteries.
If the above fails, then your remote is faulty.
Cheers,
Jul 31, 2011 | Hitachi Televison & Video
Im trying to reset my code for a sylvania 19 inch tv with my all for one URC-4605B01 remote control. I don't know the code for my tv and even if I did I don't know how to put it in with the remote. hope...
Hi There
The codes for Sylvania TVs for the URC-4605 remote are:
0054, 0030, 0171
To enter these codes manually please follow these instructions:
1. Switch the TV on.
2. Press the "TV" button on the One-for-All remote
3. Press and hold the "SET" button on the remote until the LED flashes twice, then release the "SET" button
4. Enter the first four-digit code listed above - 0 0 5 4 - using the numerical buttons on the remote.
The LED should flash twice to indicate that the code was accepted.
5. Aim the remote control towards the TV and press the "POWER" button once. The TV should switch off. If the TV does not switch off, please repeat steps 2 to 5 above, for the next code in the list.
If the TV switches off, please test the remote to make sure it controls the functions of the TV correctly - or at least as you would expect. If it works, please note the code somewhere easy to find at a later date - inside the battery compartment is a good place to keep this. If it does not work correctly, again repeat steps 2 to 5 above using the next code in the list.
Universal remotes can "forget" the code when the batteries are changed, so it's a good idea to change the batteries before re-programming the code to ensure that they are not a factor in your remote
If you cannot get these codes to work, it may be necessary to use the code search feature, or there may be a fault with your remote. If this is the case, please post back for further assitance.
Regards,
BElectric
Dec 30, 2010 | One For All URC-4605 Remote Control
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
Aug 28, 2010 | One For All URC-3021 Remote Control
Universal remote + Quasar TV = no luck. pls help!!
Do Research on the remote with the tv brand name in google. you will find something such as an manual.
Jan 05, 2010 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
