Question about Panasonic KX-TG1033S Cordless Phone
My new phone had a dial tone before the Verizon Tech left yesterday. I was to charge the base set and 2 handsets for 7 hours before using them. Now that they are charged, I have no dial tone. Message on handset either says check tel line or line in use. I have tried unplugging and replugging parts. Nothing seems to work. could you please help me. thanks (804-355-0131)
  • Anonymous Dec 10, 2008
    My telephone had worked for one week but then it suddenly stopped working, i had found out that my telephone line was dis connected so i connected it but then on the screen it said check telephone line even thogh everything was connected.
Verizon sent a technician in
Posted on Dec 05, 2008
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Jul 25, 2011 | Uniden Cordless Phone
I purchased an extra handset to a AT&T uniden E2125 system. The phone instructs me to place new handset on main base to register handset. It has registered and now it reads, handset #5. When I try...
I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
Jan 07, 2018 | AT&T E2125 (650530003738) Cordless Phone
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
No dial tone and base is constantly flashing red, I put the phone on the base to be charged and nothing is working. I turn it on but get no dial tone even though it says connecting. Constanly flashing red...
http://www.uniden.com/products/productdetail.cfm?product=ELBT595
Here is the link to the manual...
But have you tried:
1. charging the unit for 10 hours?
2. registering the handset?
Register expansion handsets to the main base
Before the expansion handset is registered, the battery pack MUST be charged for 10
hours
To register an ELX500 handset, simply place it in the main base.
To register a TCX860 handset, follow the steps below:
1) From the base, press menu/select and select S y s t e m
S e t u p menu.
2) Select R e g i s t e r H a n d s e t, and press menu/select.
3) On the handset, press and hold # until you hear a
beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
Customer Hotline at 1-800-297-1023. (Mon - Fri 7 am to 7 pm,
Sat/Sun 9 am to 5 pm, CST. Phone support is closed on holidays.)
Jun 19, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
717 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
