Question about Akai CFTD2085V 20" TV/VCR/DVD
I have a AKAI CFTD 2085 model tv. Is it digital or do I need a converter box?
  • rollmjr May 15, 2009
    I also need to know if the AKAI model CFTD2085 has a digital tuner or an analog tuner. The owners manual does not say. Nor in the specifications section does it say that it is ATSC. If it is, then it is a digital tuner.
    Problem Solver:
  • 7 Answers
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Posted on Dec 04, 2008
Can you hook up a digital converter to a akai model num lct3201td 32 inch tv
The converter box connects to the antenna input of your TV or, for better picture quality, L audio, R audio, and video outputs from the box can be connected to corresponding inputs on the rear of your TV.
Nov 02, 2016 | Akai LCT3201TD 32 in. LCD Television
Is my akai projection tv digital ready or do i need to purchase a converter box.
depends if you have a cable service. Cable companies will still broadcast in analog because they are a closed system same with sat. only other way to tell if you have a digital tuner is by one a cable/satalite card or when doing the tv programing it asks digital?
Apr 14, 2009 | Akai PT4298HD Rear Projection Television
Akai model cftd 2085
RCA JACKS,,SELECT INPUT IN THE MENU,,1,2,..AND SO ON
Jan 25, 2009 | Akai CFTD2085V 20" TV/VCR/DVD
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    I am looking for a akai cftd 2011 remote control
    I need a remote for a CFTD 2011 for an Akai Tv/DVR
    Sep 18, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
    HDTV?
    HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
    Bill
    Feb 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
    Only two channels akai CFTD 2011 20in
    no u nee dto scan for chs ? let it find them all over agian ok
    Jan 06, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
    Only two channels
    need to scan for chs in menu of the tv and add hd antenna if u havent yet maby better one like non powered
    Jan 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
    Akai CFTD2085V 20" TV/VCR/DVD Logo
    182 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
