Question about Cobra 29 LTD CB Radio
Cobra classic 29 ltd
When i hook up my cobra classic 29 ltd it shows me the channel but i dont hear any static or people talking. Also when i key up the needle dosent move and the light to show the needle wont come on
  • reg537 Jan 10, 2009
    my radio will only work within a couple hundred yards of another truck, I do not here static on the radio, and the needle does not move unless I talk or try to.
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Posted on Jan 06, 2009
I would say its a final. The light not coming on is a seperate problem. Mos radios throw to much power to the meter light when components go bad and that burns the bulb out.
Posted on Dec 06, 2008
Cobra 29 now Ltd classic Cobra 29 nw.ltd classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
Jul 13, 2014 | Radio Communications
When i try to calibrate my cobra 29 ltd classic the needle will not go to the right
make sure you have your radio set on CAL and then adjust the knob that says adjust .Turn it all the to the right then bring it back to the set point on the dial then un key the mic,move the switch to SWR , key the mic and that is your reading. Do this on channels 40 - 1 then 19. Make sure you write down the readings for each channel. The adjust your antenna from there.
Jul 05, 2014 | Cobra 29 LTD CB Radio
When do you know if you have a decent radio
The 29 has a built in SWR meter--check the match to make sure it is below 2 (lower the better).
The radio can be peaked for better than factory audio.
If the squelch is up too high you will not hear people below a certain signal level---in your case set it so you hear who you want to and not jokers.
RF gain lowers signal the radio sees for receive.
The stock mic will work but make your voice somewhat flat sounding---a power mic or having the mod limiter removed will make the radio and your voice louder.
Let me know if questions.
Jun 10, 2012 | Cobra 29 LTD CB Radio
How can I fix my cobra 29 nw ltd classic? Everything works but the channel does not display and all I hear is static.
Check TR22 which is a 2sc1957 transistor mounted on side of case near heatsink for driver and final, left rear with speaker cover removed. Make sure the legs are not contacting case. Then check resistors R115, R116, R117 for open circuit and C133 for continuity.
I figure that 2sc1957 transistor is shorting to case or failed. A 2sc2314 is a sub for this transistor.
Oct 01, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 25 ltd classic that I bought from a CB shop it was fixed to have 50 W .you can see all the changes made on it .I have it hooked up with two wips 4 ft 1000 w fire sticks and a power mike it...
either he over tuned it and burned the radio out this can happen just cause a radio transmits 50 watts dosent mean the circuity can handle it and it will burn the radio because of overload. another factor is if you are running high swrs with that kinda out put you will fry it sounds like its getting hot and radios dont work well when they get hot take it to a tech tell him what was done to the radio and what it is doing. you can test the radio by buying a watt modulation meter it will tell you excacley what the radio is putting out I doubt its transmitting 50 watts that is a single final radio unless he modified the final.good luck.
Jan 15, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
I have the cobra 29 classic k40 antenna. The antenna light comes on when keyed up on 40 but only channel 40. I used an swr meter and that's as good as I can get. Is this ok?
Normally the swr should be set on the centre channel so if you have 40 channels you should set it on channel 20. This is because as you move away from channel 20 the swr rises slightly more for each channel away from the 20. If you set it on channel 40 you'll have twice as much swr on channel 1 more than if you set it on channel 20. If the swr metre shows 1:1 (i.e. doesn't move up at all) on channel 20 the rest should be ok since the antenna was designed for CB. You should however check that the needle showing reflected power doesn't go above 2.5
Jul 29, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
GREAT TRANSMISSION HARDLY NO RECEPTION
need to take it in to have the SWR set on antena
Jan 22, 2009 | Cobra 19 DX III 40-Channels Base CB Radio
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
502 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
