Question about Casio DR250TM Calculator
CASIO DR250TM CALCULATOR
I have the users guide for the calculator, but I can't set the correct time and date. Would it be possable to get a step by step on which keys I should be using to get this fix?
Thank you,
  • ltetzke Feb 11, 2009
    Thank you, worked great.
    The User's Guide didn't say anything about holding the key down, until numbers came back.
    Again thank you.
  • eenriquez Feb 18, 2009
    How can I set the time and date?
    Thanks.
In case you haven't found the solution yet. This is it.
Move buttons to "Print" and "F"
Press CA key
Press % (set Key)
Press "time"
Press and hold down the % (set key) until the numbers come back and start flashing.
Put in the correct numbers.
Press % (set key) again and your done.
Hope this helps.
Linda
Posted on Feb 11, 2009
Where can I find a user guide or manual for the Casio HR-100TM calculator?
Couldn't find a manual or user guide. The closest I got were two pages, one with the calculator, and one with the group of calculators that explains some of the functions.
If you have a specific questions, please ask.
Good luck,
Paul
Mini printer Compact Type Printing Calculators Calculators CASIO
http://www.casio-intl.com/asia-mea/en/calc/printing/miniprinter/product_list/?m_no=145
May 14, 2016 | Casio HR-100TMPlus Calculator
Old Casio CP-10 printing calculator w/calendar
just press the set button followed by the numbers for setting time
Jun 25, 2008 | Casio Office Equipment & Supplies
Set time and date on casio dr-270tm
I ACTUALLY HAD A HARD TIME MAKING THEIR STEPS WORK. BUT WHAT I FINALLY FIGURED OUT WAS THE "FORMAT" WASN'T CORRECT. I WOULDN'T MOVE PAST THE DAY WHEN I WAS SETTING THE DATE. IT WOULD ENTER THE MONTH OK BUT THEN STOP AT THE FIRST DIGIT OF THE DAY AND WOULDN'T ADVANCE TO THE 2ND DIGIT. BUT WHAT I FIGURED OUT WAS THAT THEY WANTED THE DAY AND MONTH SWITHCED. SO INSTEAD OF ENTERING 07-29-2015 I HAD TO ENTER 29-07-2015 HIT TIME TIME AND IT WAS DONE. VERY FRUSTRATING BECAUSE THE MANUAL SAYS TO ENTER IT THE AMERICAN WAY 07-29-2015. ANYWAY, IT WORKED FOR ME. HOPE THAT HELPS. :o}
Aug 29, 2013 | Casio DR-T220 Calculator
IT IS STUCK WITH AN M IN THE TOP LEFT CORNER- JUST NEED IT TO ADD- WHAT TO DO
The M stands for memory, you should be able to locate the M key on the calculator, press it and it should go away.
May 28, 2011 | Casio DR250TM Calculator
How to set time in casio calculator fx-8100
1. Press AC
2, Enter the time as a four figure number, e.g. 0530 for 5hrs and 30 minutes or 1002 for 10 hrs and 2 minutes
3. Press the PM button in the botton row IF you want the time to be in PM, otherwise not.
You can use the 24-hour clock and the PM will be automatic, thus 1802 displays as PM 6 - 02
4. Press the small ADJ/SET button in the top white row. If you press this exactly on the minute the seconds will be correct.
5. I can give more instructions, on the timer/stopwatch functions (T/S) and the Alarms. My User's Manual is in Japanese, and I only read and speak English, so I cannot post the User's Guide.
Sep 25, 2010 | Casio SL910LA Calculator
How to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Feb 28, 2010 | Sharp EL-1801P Calculator
How do i change the time and date
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 22, 2010 | Casio DR-T220 Calculator
Changing the date.
Setting the date:
Setting the time:
displayed.
Jan 15, 2010 | Casio DR-T120 Calculator
How to set date and time on a casio qa-300 calculator
Are you sure that there is such calculator, look here casio calculators manuals:
http://www.theusermanualsite.com/ex/thread/view/idThread/1647547
Rate me if it helped
Jun 24, 2009 | Office Equipment & Supplies
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
Casio DR250TM Calculator Logo
390 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
